 Help-Accessory tensioner threads stripped
Mattwa
PostSubject: Help-Accessory tensioner threads stripped   Sun Nov 25, 2012 1:27 am
After going though all the fun of replacing all the belts and pullies, I attempted to put the accessory belt on. I pulled back the tensioner, and noticed the bolt started turning on me after kinda struggling to get the belt on. Well the threads inside the tensioner stripped. frown Is there anyway I can fix this? I'm trying to think of ways to fix it, but I don't want to ghetto-rig it up or anything. I really rather not replace the whole thing after tearing the top end apart of the motor and putting it back together this weekend.
Thanks
Matt
Merit : 134
PostSubject: Re: Help-Accessory tensioner threads stripped   Sun Nov 25, 2012 3:48 am
I don't know if you need a helicoil kit with reverse threads or if you can insert a helicoil the
necessary way. Might want to look up tensioner price (napaonline or rockauto or a local jukyard).
I am thinking junkyard tensioner.
PostSubject: Re: Help-Accessory tensioner threads stripped   Sun Nov 25, 2012 8:01 am
I believe that is a left-hand threaded bolt? If so you'll need a left-thread helicoil, not sure how readily available it would be to you unless you happen to have a mcmaster-carr or grainger store around, or a really good hardware store, or a machine shop supplier... it's the only way to repair something that critical. You can order one online I'm sure.
It may be easier to get a whole new (or used) tensioner. At 141K it may not be such a bad thing to get a new tensioner assy anyway.
Mattwa
PostSubject: Re: Help-Accessory tensioner threads stripped   Sun Nov 25, 2012 10:41 am
Ok thanks. Yes it's left hand thread. It actually has 145k now, and I'm sure it's orginal. The pulley I replaced had a shim behind it for some reason, so I'm sure it was messed with before. I wasnt cranking on it that hard.
Merit : 134
PostSubject: Re: Help-Accessory tensioner threads stripped   Sun Nov 25, 2012 7:38 pm
I am thinking it's best to replace the tensioner assembly, and I realize that the least $$ you are in for walking into a parts store off the street is high. You can use the web to get prices from the local parts stores and comparison shop. If you can wait (not long they are quick) consider getting parts from rockauto.com. also seriously consider a junkyard. The people in the parts warranty business have really whipped many junkyards into shape as far as parts quality is concerned. That is, if you buy an "extended warranty" from a dealer or 3rd party they now mostly specify that used parts must be used if available. So the better junkyards are providing better parts on balance, so they can tap into that stream of business.
Mattwa
PostSubject: Re: Help-Accessory tensioner threads stripped   Sun Nov 25, 2012 8:20 pm
Luckily the local autozone had one in stock for $75, so I bought it. Really nice piece. The old one and the old plastic elbow was in pretty bad shape, glad I got it replaced.
