 Vacuum Line Leak Test?
Go to page : Previous  1, 2
Vacuum Line Leak Test? - Page 2 Empty
PostSubject: Re: Vacuum Line Leak Test?   Vacuum Line Leak Test? - Page 2 EmptyMon Nov 16, 2015 4:29 pm
LARRY70GS wrote:
Brake booster needs about 10" minimum to function.  Do you have power assist?  The booster itself can leak.  Try pinching off the booster supply while watching the gauge.
Very true, but would probably result in a "hiss" that would be audible inside the car.
At this point, who knows....
Merit : 111
PostSubject: Re: Vacuum Line Leak Test?   Vacuum Line Leak Test? - Page 2 EmptyMon Nov 16, 2015 5:06 pm
Maybe, depends on where it is leaking and how bad.
» 2.5LB Test Curve Rods - Optimum Setup
» Fluorocarbon line
» NEED HELP - Monofilament line & HOOKS/TREBLES size.
» New reel line
» Line cutting knife
