 95 AC
jbeganny
95 AC Empty
PostSubject: 95 AC   95 AC EmptySun Jan 13, 2013 6:29 pm
This is not exactly a new topic because I asked about it previously without some new information. Yesterday I read a post by someone here (I think it was an administrator) who had downloaded schematics and part numbers which shed light on a problem I tried to explain before and to which nobody could give me much of an answer. With this new insight I can explain it better. I went and had my AC tested with the dye (95 Riv w/ SC) and it showed a leak on what I now know is the Tube Assembly Evaporator (25607525). This is the piece with the high pressure and low pressure valves. It comes from inside the car, out towards the windshield washer tank, goes under the windshield washer tank, curls around by the inner fender and comes out by the radiator where it couples with another piece. OK. I know the leak is in this Evaporator tube But wait. There is another coupler dividing the tube into two pieces between the low pressure valve and the high pressure valve but the schematics only lists it as one part number. In any case, I need the evaporator tube and I am hoping I can get a used one from someone here. Either that or can that be repaired somehow? Or does that part from another vehicle fit the Riv? On Monday I am going to go to a junkyard and browse. Anybody here got one?
florence_x
florence_x
Merit : 21
95 AC Empty
PostSubject: Re: 95 AC   95 AC EmptySun Jan 13, 2013 6:56 pm
If I had thought to part mine out before I donated it, you woulda been able to take mine. Sorry.
jbeganny
95 AC Empty
PostSubject: Re: 95 AC   95 AC EmptyMon Jan 14, 2013 10:58 pm
Thanks Florence. I am hoping someone with some 95 parts will have one available.
95 AC Empty
95 AC
