| Dash Lights Not Turning On | |
+17dboydakid rivy96 Rickw GMfan1111 L67 turtleman 99prixgt Mr.Riviera Karma ricos20002 TType_Riviera T Riley deekster_caddy albertj jax95riv ZEP yankeeselke 21 posters |
yankeeselke Special
Name : Dillon Joined : 2008-01-28 Post Count : 7 Merit : 0
| Subject: Need help with dash lights Tue Jan 29, 2008 8:36 pm | |
| When turn on parking or headlights the dash goes dim and heater and the radio lights go out. Have replaced headlight switch and heat sink dimmer on the steering column Also inst pannel. Going to try sentinel next. ??? Any ideas??? Anything could help!!! thanks | |
ZEP Fanatic
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 9:06 pm | |
| Have you checked your fuses on the side panel and under the rear seat? I had this sort of problem about a week ago trying unsuccessfully to install some LEDs in my car. The fuses blew, so that might be your problem. | |
yankeeselke Special
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 9:09 pm | |
| I have checked all fuses and they are ok. Have pulled radio and heater control and it still happens. Also when pull on light switch rpms go up too and dash lights go dim. | |
jax95riv Aficionado
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 9:34 pm | |
yankeeselke Special
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 9:46 pm | |
| no its not that, its still charging. | |
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 10:38 pm | |
| All the fuses? there are several panels.
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 10:40 pm | |
| what's your running voltage? Poor ground? Battery terminals tight?
Do you have any trouble starting?
It's very hard to help diagnose with the information you've given. Please give us...
I'm guessing you've got a loose ground connection under your dash somewhere. | |
yankeeselke Special
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 11:02 pm | |
| 13.7 running voltage. Have run ground wire from battery to engine and frame. Car starts ok. If i test headlight switch and heat sink i can get test light to dim. Also console lights inop. I have gone on line and i know this has happened to other ones. Was a mechanic for 30 years and this is my sons car. Have pulled electric and other connections. When the lights come on the sentinal relay clicks. ???? | |
T Riley Guru
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 11:07 pm | |
| - yankeeselke wrote:
- this is my sons car.
did you make him the profile?? Good dad my dad just referred me | |
yankeeselke Special
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 11:10 pm | |
| no he did, but i have been trying to help him out with this problem for over a month now. | |
T Riley Guru
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 11:11 pm | |
- no he did, but i have been trying to help him out with this problem for over a month now.
oh i c......... im sure you'll edventually find out a way..... sorry i am electrically challenged... | |
yankeeselke Special
| Subject: Re: Dash Lights Not Turning On Tue Jan 29, 2008 11:26 pm | |
| Subject: Re: Dash Lights Not Turning On Sun Feb 03, 2008 9:26 pm | |
| Are you saying that (1) you got the car a month ago and this has always been a problem, or that (2) you repaired something else and this problem came up, or that (3) you/son installed something else and this started happening, or that (4) it (dimming) started happening for no apparent reason?
Please advise... because now that I've read this far my first reaction is sounds like a botched repair of someting else, or a piece of non-factory electrical equipment gone awry -- but I need for you to fill us in on the details. Which (1 thru 4) obtains?
TType_Riviera Fanatic
| Subject: Re: Dash Lights Not Turning On Sun Feb 03, 2008 10:35 pm | |
| sounds like a bad ground... | |
yankeeselke Special
| Subject: Re: Dash Lights Not Turning On Wed Feb 13, 2008 8:30 pm | |
| Thanks i think it is the i-pod that went into the factory radio. When i got the original heat sink the box was open. I also replaced the sentinal module and everything was the same. I got a new dimmer heat sink and everything was working fine until my son plugged in the ipod using the tape deck and it blew again. I have got him a JVC stereo with mp3 cap and wondering if there is a way to wire it so the steering wheel controls will work. Any help will be greatly appreciated | |
| Subject: Re: Dash Lights Not Turning On Wed Feb 13, 2008 10:14 pm | |
| If the stereo has an IR remote you should look up a pac swix. (google) | |
| Subject: Re: Dash Lights Not Turning On Thu Feb 14, 2008 9:41 am | |
| OK, now I get it. Your mods are killing you.
The steering wheel controls work by signaling. Each steering wheel switch puts a different resistance into line with the bus. The radio responds depending on what resistance hits the bus.
As for the iPod/tape deck interface, are you sure there is not something wrong, maybe shorted, in the fake-y cassette gadget?
I have not done this (yet) so it's at your own risk, BUT what you could try is an iPod interface. There is one here:
http://www.theistore.com/peripheral_electronics_ipod2car_pxdp_interface_kit?gclid=CL6Arp3xw5ECFRGCGgodaGBDDg
You need some extra bits to make it work but if you go to the web link there are pointers to the extra bits you need to buy. You may need to delete the "?gclid..." et cetera to make the link work, or start from the root (www.theistore.com).
In general - what you'd do is restore the wiring to straight factory, *no* mods whatsoever. Then with the iPod2car interface and the extra bits, connect the iPod to the CD interface that the Riv radio already has.
I do not know if an ipod2car inteface is available for the JVC head unit, and I do not know if you really want to remove the factory head unit because as I understand it ther eare some non-radio functions that the factory radio does for the car - I don't remember right this second what they are.
Good luck and please let us know how it cones out if you decide to tke the plunge (about $150 and a couple hours).
ricos20002 Member
Name : Robert Age : 40 Location : Copperas Cove, Texas Joined : 2008-10-22 Post Count : 84 Merit : 1
| Subject: dash lights Thu Jan 22, 2009 9:03 pm | |
| I need a wire schematic for the dash lights and dimming circuit. Please. Everything works, automatic lights, Parking lights, and door lights. I was thinking it was a fuse couse the rear defrost doesnt work ether but I checked them and they seamed fine, Im going to check them again | |
Karma Aficionado
| Subject: Re: Dash Lights Not Turning On Thu Jan 22, 2009 10:15 pm | |
| This what you need?: https://2img.net/h/i240.photobucket.com/albums/ff27/karmag3/dashwiring.jpg _________________ | |
| Subject: Re: Dash Lights Not Turning On Thu Jan 22, 2009 11:11 pm | |
| did you run an ohm meter over ALL the fuses? (console and under seat, even if the label has nothing to do with it) _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
ricos20002 Member
| Subject: Re: Dash Lights Not Turning On Fri Jan 23, 2009 7:25 pm | |
| - Mr.Riviera wrote:
- did you run an ohm meter over ALL the fuses? (console and under seat, even if the label has nothing to do with it)
every fuse is good. I check under the set, under the hood, and in the dash. Im about to take it back to were I have the alarm put in. But its one of thoes " not responsible for damages" kind a place. so I dont know. What all could it be? Dimmer, light control module, ??? Were is the control module? | |
| Subject: Re: Dash Lights Not Turning On Fri Jan 23, 2009 7:53 pm | |
| if they had the dash apart, could they have forgoten to plug the dimmer back in?
i dont think the rear defrost problem is connected btw. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
ricos20002 Member
| Subject: Re: Dash Lights Not Turning On Fri Jan 23, 2009 7:58 pm | |
| - Mr.Riviera wrote:
- if they had the dash apart, could they have forgoten to plug the dimmer back in?
i dont think the rear defrost problem is connected btw. I was thinking they might of pulled or didnt hook up a ground, couse its just the lights and rear defrost. I dont know. The dimmer is in the swich right? Maybe I could pull it off and test it some how, does anyone know the pin out for it? | |
ricos20002 Member
| Subject: Re: Dash Lights Not Turning On Wed Jan 28, 2009 9:32 pm | |
| I fixed my problem. they call it an "Instrument Cluster Dimmer Switch" $25.92 everything works now. Thanks for everyones help | |
99prixgt Member
Name : Erik Age : 37 Location : NJ Joined : 2009-01-27 Post Count : 90 Merit : 2
| Subject: Re: Dash Lights Not Turning On Thu Feb 05, 2009 11:36 pm | |
| wow this was all so familiar, I had the same problem on my 95' and i never figured it out. | |
| Subject: Re: Dash Lights Not Turning On | |
