 Radio stays on after turning off ignition?
96RIVMANN
96RIVMANN
Radio stays on after turning off ignition? Empty
PostSubject: Radio stays on after turning off ignition?   Radio stays on after turning off ignition? EmptySun Feb 03, 2013 2:00 am
Just like the topic says when I exit the Riv the radio stays on. I'm sure it's a relay does anyone have any idea where it's located?
Thanks
PostSubject: Re: Radio stays on after turning off ignition?   Radio stays on after turning off ignition? EmptySun Feb 03, 2013 8:20 am
Nothing on this car is that simple. You are referring to a problem with the RAP, Retained Accessory Power circuit. There is a diagnostic in the FSM. Some of the components listed are the remote function actuator module (under the speaker deck in the rear), and the DAB Accessory relay in the LH rear junction block under the rear seat. You could try looking at that relay. The door switches are in the latch mechanism. The whole system should time out in 10 minutes. Does it do that?
96RIVMANN
96RIVMANN
PostSubject: Re: Radio stays on after turning off ignition?   Radio stays on after turning off ignition? EmptySun Feb 03, 2013 11:43 am
It used to time out after 20 minutes but stays on. I'll have to take a look at my FSM. I thought I would post in case someone else had a similar problem.
Thanks
PostSubject: Re: Radio stays on after turning off ignition?   Radio stays on after turning off ignition? EmptySun Feb 03, 2013 12:24 pm
Is your dome ligh/t working properly
PostSubject: Re: Radio stays on after turning off ignition?   Radio stays on after turning off ignition? EmptySun Feb 03, 2013 2:54 pm
that's what I'm thinking too. Either the door switch isn't triggering or there might be something else wrong with the wiring or the controller.
The radio is supposed to turn off when you open the door (and the dome light comes on)
96RIVMANN
96RIVMANN
PostSubject: Re: Radio stays on after turning off ignition?   Radio stays on after turning off ignition? EmptyMon Feb 04, 2013 12:18 am
Don't what I did but all is back to normal. Thanks for the replies.
shocked
Merit : 155
PostSubject: Re: Radio stays on after turning off ignition?   Radio stays on after turning off ignition? EmptyMon Feb 04, 2013 8:23 pm
shocked
if you did not check the wires in the drivers side door jamb pass through you might want to do so.
PostSubject: Re: Radio stays on after turning off ignition?   Radio stays on after turning off ignition? EmptyTue Feb 05, 2013 12:34 am
I hate to say it, considering it's all supposed to be solid state, but I've gotten used to a sort of random RAP... Delays in what should happen, or a light in an open trunk that won't come back on by just cycling the latch switch like the other 90 times. dunno
Rivillac
Rivillac
PostSubject: Re: Radio stays on after turning off ignition?   Radio stays on after turning off ignition? EmptyTue Feb 05, 2013 8:50 am
X2
Sometimes it'll work like normal no matter what I do, sometimes it won't work like it's supposed to no matter what I do. suspect
Rivillac
Rivillac
PostSubject: Re: Radio stays on after turning off ignition?   Radio stays on after turning off ignition? EmptyMon Nov 10, 2014 9:50 pm
FWIW, while trying to track down another problem, I sprayed the latch mechanism down with Electrical Contact Cleaner, and the RAP has become very normal and predictable. Some food for thought.
» Micron Radio Control
» New info on MSD ignition for 09 Teryx
» Radio Reporter Needed
» Rhino Radio?
» Moose overhead radio unit
