 SOUND LIKE A SODA CAN IN MY ENGINE.....HELP
simba510
simba510
Merit : -1
SOUND LIKE A SODA CAN IN MY ENGINE.....HELP Empty
PostSubject: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 12:05 pm
i have a weird knocking under my hood it sounds like a soda can bouncing around ive never heard it on any car before im hoping that someone can id it ill post a vid in a minute
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 12:52 pm
Scrap it. It's a rod knock. Your motor is fucked.
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 1:04 pm
I agree it sounds like the bottom end (rod bearings). Bad news: engine needs rebuilt.
Good news: rebuilds are not too expensive for these engines. Probably $1600-2000 if you find the right shop. Or you might find a used engine and have someone swap it in. Sorry about your luck, hope it works out.
simba510
simba510
Merit : -1
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 1:38 pm
thanks yall
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 1:54 pm
Best of luck, Simba. Don't give up yet! rock
simba510
simba510
Merit : -1
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 1:59 pm
im not its getting picked up in a few mins
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 2:00 pm
Could also be the harmonic ballancer. I have heard 2 different rivs make awful knock sound when the balancer fails.
Take a look/feel at it and see if the rubber has cracked around the center. also look for it to wobble when the car is running.
Mine failed at about 130k and so did a friends 97 riv.
SOUND LIKE A SODA CAN IN MY ENGINE.....HELP Dsc_0110
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 2:37 pm
Check the harmonic balancer. If it's a bearing definitely look for a used motor. Can be a LOT cheaper than a rebuild and have a lot of life left in it if you find a lower mile engine.
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 4:11 pm
L26 block FTW
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 4:28 pm
Yup it's toasted mine sounded just like it,fill with mmo and a bottle of Lucas probably get 5000 miles out of it or more drive her easy!!
simba510
simba510
Merit : -1
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 7:25 pm
what would cause rod knock or the balancer to fail?
well shes of to the shop now tow truck jus came to pick her up
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 9:41 pm
Rod knock means the a connecting rod bearing is worn, makes the rod loose on the crank shaft. Lack of oil or a lot of stress will cause this.
SOUND LIKE A SODA CAN IN MY ENGINE.....HELP Images?q=tbn:ANd9GcQ-e-53GwvG-g68xrRZJ18Qaqr01CzK_Xx7t0jH6bG4KnQLc4Fx
Here is a Corvette piston with connecting rod for reference:
SOUND LIKE A SODA CAN IN MY ENGINE.....HELP GM-Chevrolet-Z06-LS7-Piston-and-Connecting-Rod-Assembly
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 9:59 pm
i would check the HB.it makes a sound similar to a bad bearing that will have your wallet shitting in your backpocket.
simba510
simba510
Merit : -1
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyTue Feb 12, 2013 10:03 pm
thanks AA THAT WAS VERY HELPFUL THE SHOP SAID I SHUD BE BACK UP BY NEXT WEDS
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyWed Feb 13, 2013 5:38 am
What did the shop say your issue was?
simba510
simba510
Merit : -1
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyWed Feb 13, 2013 6:06 am
dont know yet they poppin her open today but he said he gonna try to get me back on my feet asap
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyWed Feb 13, 2013 8:25 am
Be careful paying unless you know what's wrong before they start. Make sure they quote you first.
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyWed Feb 13, 2013 9:38 pm
THIS.....
moldymac
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyThu Feb 14, 2013 10:04 am
Just a word of caution: When the balancer went one my old lesabre (3800 engine) I took it to 3 shops that all said rod bearings. It turned out to be the balancer though.
Yours does sound like the bearing though, have a listen in my videos:
bad balancer:
series I knock (fast forward to 2:20)
Series II knock (fast forward to 4:45)
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyThu Feb 14, 2013 10:08 am
Man, the engine bay in the last video is NASTY. dang.
moldymac
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyThu Feb 14, 2013 10:43 am
I bought that one from someone who let it rot in the woods for a few years. The easiest way to clean it was a new engine lol
simba510
simba510
Merit : -1
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyFri Feb 15, 2013 5:13 pm
HOW MUCH IS A NEW ENGINE FOR THE 97 RIV?
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptyFri Feb 15, 2013 6:33 pm
I sold a '98 with 67k SC 3800 for $800. I thought I gave the kid a pretty good deal.
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptySat Feb 16, 2013 10:34 am
ITS A LOT OF MONEY
moldymac
PostSubject: Re: SOUND LIKE A SODA CAN IN MY ENGINE.....HELP   SOUND LIKE A SODA CAN IN MY ENGINE.....HELP EmptySun Feb 17, 2013 10:05 pm
I went the junkyard route on both of mine, paid $600 for them, tested.
» Mintor 33cc Petrol engine
» engine knock
» RCGF 45cc Petrol Engine
» Tecumseh engine
» How man cc is an 11hp engine?
