 Sudden squeal on way home
Sudden squeal on way home Empty
PostSubject: Sudden squeal on way home   Sudden squeal on way home EmptyFri Feb 15, 2013 9:45 pm
so i was on my way home tonight from the store and about a mile from the house i hear a loud squeal thought maybe a brake grabbin but i got home and in park it continued. its dark so i let it cool and then took a flashlight and checked the oil, coolant and still warm atf all good. due to powersteerin placement i cant check that till morning but any ideas folks????
btw when its wet the belt squeals but its been dry for 3 days here. also i checked the belts they are both in great shape. im at a loss
PostSubject: Re: Sudden squeal on way home   Sudden squeal on way home EmptyFri Feb 15, 2013 10:34 pm
Check for moisture from a leaking water pump. If no leak, spray with water bottle - if it squeals more, it means belts is slipping. If water makes noise go away, it's a misaligned pulley.
PostSubject: Re: Sudden squeal on way home   Sudden squeal on way home EmptySat Feb 16, 2013 10:37 pm
no water leakage. squirted water and it stayed about the same. it sounds like metal on metal. im thinking its a pulley. o and ps fluid is good too
Merit : 153
PostSubject: Re: Sudden squeal on way home   Sudden squeal on way home EmptySun Feb 17, 2013 7:05 am
If you have metal idler bullies, with engine off slip off the belts and turn idlers bu hand. Replace the ones that do not turn properly.
PostSubject: Re: Sudden squeal on way home   Sudden squeal on way home EmptyMon Feb 18, 2013 6:45 pm
well i opened the hood in the sunlight for the first time since this started and i imediately saw the problem. the a/c pulley had metal shavings on it! i just replaced it last summer but with a USED ac compressor. wont do that again so as soon as possible i got to buy a new ac compressor
PostSubject: Re: Sudden squeal on way home   Sudden squeal on way home EmptyMon Feb 18, 2013 7:42 pm
Just to be sure, detension the belt and try moving the AC compressor on its mounts. If it's worked loose, it can cause the problem you're having.
PostSubject: Re: Sudden squeal on way home   Sudden squeal on way home EmptyMon Feb 18, 2013 9:45 pm
my nephew looked before i left home and said he thought it was missin a bolt. how many holds it? i think you just may have saved me a lot of money
PostSubject: Re: Sudden squeal on way home   Sudden squeal on way home EmptyTue Feb 19, 2013 12:20 am
At least 3. The AC pump is mounted to a cast iron bracket, which is mounted to the block. Check the bolts connecting the pump to the bracket.
» home made lures
» Home made pike tackle
» Have A Great TWH To Give Away To A Good Home
» Welcome Home Viet Nam Vets Day, March 30 2011
» home made quick release steering wheel???
