| Since the Riv is toast.....(engine swap question) | |
98riv65lark Member
| Subject: Since the Riv is toast.....(engine swap question) Thu Jun 07, 2007 9:51 pm | |
| How hard would it be to swap my front wheel drive 3800 into a rear wheel drive 1970 Datsun 510/240/260/280Z? | |
| Subject: Re: Since the Riv is toast.....(engine swap question) Thu Jun 07, 2007 11:19 pm | |
| Toast? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
98riv65lark Member
| Subject: Re: Since the Riv is toast.....(engine swap question) Fri Jun 08, 2007 12:52 am | |
| Accident......too much money to fix on a military salary. | |
jax95riv Aficionado
| Subject: Re: Since the Riv is toast.....(engine swap question) Fri Jun 08, 2007 6:40 am | |
| Interesting thought. I was thinking earier in the week what it would be like to put an engine in the rear of our cars since our trunk area is so large...like something Italian. | |
urbsnspices Fanatic
| Subject: Re: Since the Riv is toast.....(engine swap question) Fri Jun 08, 2007 7:41 am | |
| Swapping the engine into a Fiero is the most common. There is a lot of info out on how to do it. L67swap.com recently changed to this: http://forums.motorswap.org/ | |
pwmin Enthusiast
Name : Paul Age : 43 Location : Denver, CO Joined : 2007-01-23 Post Count : 131 Merit : 6
| Subject: Re: Since the Riv is toast.....(engine swap question) Fri Jun 08, 2007 10:50 am | |
| im sure its been done into a datsun, but yes, the fiero swap is common, but to find a nice 88 GT is at least $3000 (in most cases) from what ive seen. | |
RivMan Amateur
Name : Rob Location : Ypsilanti, Mi Joined : 2007-02-20 Post Count : 28 Merit : 2
| Subject: Re: Since the Riv is toast.....(engine swap question) Fri Jun 08, 2007 1:10 pm | |
| You'll need the transmission from a 3800 Camero, and you'll have to fab up some type of TB adaptop so that your TP dosen't stick through the firewall.
-Rob | |
| Subject: Re: Since the Riv is toast.....(engine swap question) | |
