 riv sounds a bit like a diesel
sniperdude
sniperdude
Merit : 18
riv sounds a bit like a diesel Empty
PostSubject: riv sounds a bit like a diesel   riv sounds a bit like a diesel EmptyFri Feb 22, 2013 3:23 pm
Hey all. Here's a vid of my car at idle. It sounds quite a bit like a diesel.
I saw some smoke coming out of the exhaust pipe near the headers when I throttled the motor (it looks like there might be a crack in the piping)
Does this sound like an exhaust leak?
sniperdude
sniperdude
Merit : 18
PostSubject: Re: riv sounds a bit like a diesel   riv sounds a bit like a diesel EmptyFri Feb 22, 2013 3:25 pm
I saw some exhaust smoke coming out of the back of the motor too, so there is a high possibility there is an exhaust leak.
PostSubject: Re: riv sounds a bit like a diesel   riv sounds a bit like a diesel EmptyFri Feb 22, 2013 11:55 pm
From what I've read, its not uncommon for the exhaust manifolds to get small cracks in them over time. Never experienced this first hand but have also read it creates a ticking sound which can be picked up as false knock by the knock sensors.
» Has anyone else swapped in a diesel, air-cooled or water?
» YANMAR 24 HP DIESEL TRACTOR
» Bad diesel fuel
» 2008 Toyota Tundra Diesel Dualie - 1-Ton Diesel Truck
» What do you think about the diesel Polaris
