 Write-Up: Brake Line Repair
manofmany
Write-Up: Brake Line Repair - Page 4 Empty
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyTue Oct 05, 2010 3:51 pm
I'll be using the proper fittings smile
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyTue Oct 05, 2010 4:20 pm
well..you'll have to post pics to prove it.otherwise its just so much fluff.
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyTue Oct 05, 2010 7:39 pm
Are our break lines made to fit ( pre-bent) by anyone yet?
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyTue Oct 05, 2010 9:22 pm
Not to my knowledge.
manofmany
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyTue Oct 05, 2010 9:26 pm
I'll be sure to post up pics after I get the parts and get the line bent and assembled. smile
And no, there are no pre-formed lines available. I looked everywhere. Called the dealer and tried gmpartsdirect. Both said the lines had to be fabricated from bulk line and fittings.
manofmany
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptySat Oct 09, 2010 1:03 pm
After doing my calculations I need about 157" of brake line.
21 bends total. Thinking about getting the line and taking it to a garage to have the bends made. Not sure I have the time or patience. Bad idea?
Merit : 147
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptySat Oct 09, 2010 1:27 pm
It should not be *that* hard to find an independent mechanic who'd like to do this - the supplies are cheap and the labor's not backbreaking. If I could spare a saturday I'd do it myself though. Kind of a noon- to - six project.
manofmany
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptySat Oct 09, 2010 1:39 pm
I'm thinking 2 60" pieces and a 40" piece.
3 pieces. This give me a 2nd section just after the bend to cross the car so it will be easier to install. Sound good? Sorry for my silly questions, just want to do this right.
Merit : 102
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptySat Oct 09, 2010 3:32 pm
Just my 2 cent's worth, but I've made many good bends with the second tool posted...
(and it didn't even have the rubber grips tongue)
Write-Up: Brake Line Repair - Page 4 Images.ashx?i=W80674
manofmany
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptySat Oct 09, 2010 3:58 pm
Got them, but forgot the unions frown
Is it typical for the threads to feel "loose" inside the adapter that was already on the car until snugged? I can wiggly it side to side a bit until tightened down.
Also, I guess these AGS brake lines can bend by hand and not kink until you try and extreme degree. They demonstrated in the store lol. Grabbed a bender anyways
Merit : 102
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptySat Oct 09, 2010 4:01 pm
Que?
manofmany
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyMon Oct 11, 2010 8:00 pm
Worst. Job. Ever.
I've got the original line replaced and in. The pressure valve bearing was lost and the line on the other apparently tweaked just enough to bust. Now I've got the entire length to the junction box.
Now I've got to get a tube cutter, rent a double flaring tool, and find the correct fitting for the junction box (or I can just reuse the old). I can only imagine how tough it's going to be getting the new line in. I'll probably do some rerouting.
Merit : 147
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyMon Oct 11, 2010 9:02 pm
manofmany wrote:
Worst. Job. Ever.
if this was the worst job - ever - then you are leading a charmed life... congratulations on tackling it though.. it's not that nice a job, dealing with underbody corrosion and frozen components.
JEGS sells a kit with tools for about $85.- is it worth it?
those of you reading thru this thread to learn about brake line replacement may find the following informative:
http://www.dimebank.com/BrakePlumbing.html
manofmany
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyMon Oct 11, 2010 9:12 pm
albertj wrote:
manofmany wrote:
Worst. Job. Ever.
I've never had to try and work under a car in gravel. Honestly, I'd rather have to replace the engine or transmission than deal with these brakes lines bonk
Actually, that kit would probably be great for someone replacing multiple brake lines. At this point, I've realized pre-bending the lines to attempt to match the old lines only works so well. I do appreciate everyones help and putting up with my rants.
manofmany
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyFri Oct 15, 2010 5:01 pm
So I went to get the pieces I needed for the other half of the line.
Come to find out, the Riviera uses a bubble flare and not a double flare frown I'm not sure now if I need to cut and bubble flare the double flared ends going into the rubber hose fitting and pressure valve or if they will be fine and not leak when tightened down. Any insight?
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyFri Oct 15, 2010 5:36 pm
do your self a favor. ditch the bubble flares. you don't need them.although they are nice. buy several unions.along with the tits that come with, a couple feet of 3/16 line.if your lucky they come with the tits preinstalled.all you have to do is cut to length.or buy the shortest length do get the job done.and fab up your double inverted flare. easier.cheaper. just as effective. a tip though,when you place the 3/16 anvil atop the double flaring tool to measure line height in relation to the tool,place the line so that it is sitting ever so slightly below the anvil. perfect and smooth every time.if you see the anvil starting to tilt.STOP, cut anew the line and start over. otherwise you'll be shopping for more than 1 anvil.
manofmany
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyFri Oct 15, 2010 7:25 pm
Well I have brakes again. The do still need bled but for the first time they hold pressure.
I was able to use an adapter with a little "tit" so to speak that the inverted flare would mate with and a bubble flare on the other end. Replaced the line all the way from the caliper to the junction box.
whatever80
PostSubject: Replacement brake lines ..avail?   Write-Up: Brake Line Repair - Page 4 EmptyThu Jul 10, 2014 10:14 am
Hi, Looking to find pre-bent (factory type) brake pipe (lines) for a 95 SC.
gm dealer guy is going to look for me but isn't hopeful. Anyone know of a source?
I really don't want to have to bend/fit all of them..esp at the abs pump.
Sorry if this has been asked before..if so please point me that way. Thanks!
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyThu Jul 10, 2014 10:57 am
It's really not that bad of a job and you would probably save some cash that way. You have to get the old line off anyways and there's no better template to use.
If you're deadset on not bending lines yourself you could take the original line to a shade tree mechanic and have him match it. He probably won't charge you to much to do it.
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyThu Jul 10, 2014 6:07 pm
My dad had stainless lines made for my 95 about 5 years ago. I dont think the price was at all unreasonable. Ill ask him the name of the place and see if he will chime in.
EDIT: this place is local so I would guess this is where mine are from.
LINK
$180 + Shipping for all new lines that will outlast the car sounds like a bargain to me!
Incase anyone has trouble with the link, it is Classic Tubing in Lancaster, NY.
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyThu Jul 10, 2014 9:57 pm
Dave is correct on the link he posted. His car was the template for these lines. We are very lucky to have Classic Tubing right in our back yard. They do a great job. Check out their website.
Merit : 147
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptySat Jul 12, 2014 3:36 pm
I would **so** have bought those lines if they were available when I overhauled my brake system!!
...that said, it was not that hard to do, just kinda time consuming -- the car was on a lift.
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptySat Jul 12, 2014 5:35 pm
Are the brake lines the same across all years?
Merit : 147
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptySun Jul 13, 2014 6:09 pm
AFAIK. And I suspect the other G-body GM cars' lines fit more or less as well.
PostSubject: Re: Write-Up: Brake Line Repair   Write-Up: Brake Line Repair - Page 4 EmptyTue Nov 17, 2015 8:35 pm
=1995&product_type_1_Make=Buick&product_type_1_Model=Riviera&product_type_1_Category=&submit=Search&vmcchk=1&Itemid=53]LINK
Do you have any pictures of the brake lines? Any fitment issues? Looks like the price jumped up since you posted the link.
Page 4 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
» Rhino Rear Brake?????
» Rhino Rear Brake AWFUL Noise -- Normal??
» SuperATV Disc Brake Conversion
» Fluorocarbon line
» RZR Parking Brake Threads
