 car runs rough when it gets up to operating temp
Go to page : 1, 2, 3, 4  Next
sniperdude
sniperdude
Merit : 18
car runs rough when it gets up to operating temp Empty
PostSubject: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 9:21 am
Hey all, I finished my front brakes yesterday and went out for the first ride in six months since I've spent time fixing it up.
It has a new starter, plug wires (acdelco), plugs (acdelco), new air filter, PCV, idle air control valve, throttle body was cleaned as well.
It ran a little rough at first, but it got worse as the temp went up. It isn't terribly noticeable while accelerating, it starts bucking and the idle is super rough.I changed my idle valve so I'm not sure why this is happening.
It has a full tank of 93 gas.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 9:23 am
It ran like that six months ago, and I thought the tune up would have alleviated the issues.
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 9:38 am
I keep thinking that its the injectors.I changed out the injector filters and o-rings.made a huge difference in idle quality.I could not afford to have them sent out for sonic cleaning but I bet that would solve My rough idle issues ,maybe yours too
sniperdude
sniperdude
Merit : 18
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 9:40 am
That makes sense.My exhaust smells like chit too.
I'm not sure if there are cats on this car, I have to check.
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 9:42 am
cats get clogged over time.Mine were.If you dont have smog in Illy,take 'em out.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 12:03 pm
Here's hoping you're right, Robo.I took it in to Firestone, they're putting it on their injector cleaning machine.
Hopefully one day I can send the injectors in to get cleaned sonically.
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 3:14 pm
Hope that works.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 6:09 pm
Yeah, they used a kit by QMI.
car runs rough when it gets up to operating temp QMIEK10T_PopBox-1
It didn't work out too well. The idle was slightly better afterwards, but it still has a really bad idle. Felt like a waste of money. Seriously out of ideas on this damn car.
Merit : 154
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 6:59 pm
Well, alright then, I guess it is time for grease-under-the-nails troubleshooting.
When you replaced the IAC did you remove the Throttle body and clean it? You will need a TB gasket (make some phone calls, in my area most parts places don't stock them but the one that does only stocks ggo felpros and keeps 6 or more on hand).
So. Let's start there. Did you remove and clean the throttle body?
sniperdude
sniperdude
Merit : 18
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 7:03 pm
Yup. IACV, cleaned throttle body, new gasket.
New Fuel filter, pcv, spark plugs, wires, vacuum lines, air filter.
Basically everything that could be related.
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 7:09 pm
I would still try and find a set of injectors from a junk yard and have them sent out for super cleaning and blueprinting.Or buy a refurbished set from Rockauto.It's an expense for sure but if you calculate the cost of running around and the hassle of diagnostics a new set of injectors dont sound so bad.Having a spare set is allways a good idea.The modern fuel injectors do clog up pretty bad and no amount of bottled cleanser or on the car cleaning will make them good again. I've been putting off buying an extra set to focus on other systems,but I think now that I've got my rad and suspension mostly squared away a set of injectors might be worth another think.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 7:18 pm
Does anybody have instructions on removing the fuel rail?
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 7:58 pm
Theyre pretty easy to remove. Looking at the injector you can see a shiny wire clip
car runs rough when it gets up to operating temp HPIM1758_zpsf9198e28
push that wire clip in towards the injector.Once the clip is completely compressed pull and tug on the electrical connector gently,remove from injector.Repeat for all injectors.
Nect turn you attention to the Vac tree atop the S/C.loosen the 10mm bolt and remove after disconecting all Vac lines.There is a wire harness that runs to the EGR valve,disconect that by prying open the plastic clip that holds it to the fuel rail.Just push the electrical harness out the way.
car runs rough when it gets up to operating temp HPIM1759_zps55b7d4ee
Now concentrate on removing all the 10mm bolts that hold the rail to the S/C body.
car runs rough when it gets up to operating temp HPIM1760_zpsfa079ff8
Gently pull and tug on the rail,it it will pop off.On reassembly you must replace all the injector orings.Go to the VatoZone and buy a set.On reassembly coat the injector o-rings with petroleum jelly to facilitate instal and prevent tearing of the o-ring.
The injectors just get pulled out.
And that is how you do it.Piece o cake.
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 8:05 pm
Go back and check your work. Make sure all vacuum lines are secure. elec connections are plugged in, clean and tight. Is your CEL on or off? , Are you able to scan?
Don't keep throwing parts at it. Checking codes or monitoring a datastream on a scan tool may give you a better idea of what is causing the problem. May be something as simple as a faulty coolant temp sensor.
Merit : 154
you'll need to pull, clean and reinstall the plugs, too. Look for differences between plugs - not the condition of each plug.
..next question, whose (new) wires did you install? Delco? Belden? Autolite?
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 8:29 pm
...The point is, the odds of 18 year old injectors being fouled beyond conventional means of cleansing is high. Kinda like having a spare tire.Allways good to have a spare.
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySun Mar 24, 2013 9:52 pm
There's a thread here about using "Mr Injector" service that I believe was about $15-20 an injector which seemed like a reasonable deal. I'm thinking about that myself.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptyMon Mar 25, 2013 7:27 pm
Thanks for all your helpful suggestions.
I have an appointment at a Buick dealer on Saturday morning to get it checked out professionally and scanned with the Tech 1 and all that nice stuff.
Hopefully I can find out what I'm dealing with.
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptyMon Mar 25, 2013 7:32 pm
Good luck to you. I hope they find it for you and fairly inexpensively!
sniperdude
sniperdude
Merit : 18
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptyFri Mar 29, 2013 6:47 pm
Thanks for this, Robo. If it ends up being injectors I'll follow this info.
I'm wondering what will come up tomorrow with their inspection. I am guessing my TCC solenoid is bad because the shaking at 45MPH sounds exactly like that issue.
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptyFri Mar 29, 2013 7:00 pm
..It's gonna be good to find out! I have similar issues but I put up with them maybe more than I should.
sniperdude
sniperdude
Merit : 18
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySat Mar 30, 2013 9:37 am
For 126 bucks, I really hope they find the issues.
Also I asked them to diagnose that gear shift indicator issue with them all being lit up simultaneously and blinking.
Will share whatever info I get. smile
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySat Mar 30, 2013 10:31 am
That sounds like it could be a PCM problem.
car runs rough when it gets up to operating temp Dsc_0110
sniperdude
sniperdude
Merit : 18
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySat Mar 30, 2013 12:17 pm
car runs rough when it gets up to operating temp Img20130330102639
PostSubject: Re: car runs rough when it gets up to operating temp   car runs rough when it gets up to operating temp EmptySat Mar 30, 2013 12:30 pm
wow man, they saw you coming lol
Page 1 of 4Go to page : 1, 2, 3, 4  Next
» My battery barely turns the starter. Could it be a bad a connection?
» Brampton's Best Youth BBall Runs
» Rough noise
» Rough Stuff tempest for sale - SOLD
» Jamaican sensation Ashmeade runs 10.05 PB
