 1999 riviera sc3.8 no start, help!!
luis1991
1999 riviera sc3.8 no start, help!! Empty
PostSubject: 1999 riviera sc3.8 no start, help!!   1999 riviera sc3.8 no start, help!! EmptyTue Mar 26, 2013 8:03 pm
So i have this 1999 Buick Riviera 3.8 supercharged and it was running fine until i did some work to it. I replaced the lower control arms, the valve cover gaskets and also an idler pulley for the supercharger the one that needs the engine mount removed. After all this, now it wont start. It has good spark, good fuel pressure, but no injector pulse. I replaced the crank sensor, cam sensor, the pcm and also part of the wiring harness(the one with the crank and cam sensor plugs and icm plug) thinking i may have messed something up while removing the engine mount. I also hooked up a snap on scan tool to read the rpms while cranking but it reads at 0, which means the pcm isnt receiving a signal from the ckps, so basically this is the problem right? Also, on rare occasions i get injector pulse for like a second and will start for that second. Can anybody help me with this problem, i will highly appreciate any help. Thanks in advance!
PostSubject: Re: 1999 riviera sc3.8 no start, help!!   1999 riviera sc3.8 no start, help!! EmptyTue Mar 26, 2013 8:34 pm
Don't know for sure what your problem might be, but a couple things you could check.Ground wire to motor at right front corner( small wire can easily brake). Security system.
PostSubject: Re: 1999 riviera sc3.8 no start, help!!   1999 riviera sc3.8 no start, help!! EmptyTue Mar 26, 2013 8:57 pm
Was the crank sensor and pcm replaced as trial and error to get the car running?
1999 riviera sc3.8 no start, help!! Dsc_0110
PostSubject: Re: 1999 riviera sc3.8 no start, help!!   1999 riviera sc3.8 no start, help!! EmptyTue Mar 26, 2013 10:17 pm
Sorry your Riv is messed up but I'm glad it brought you to the club. hi
PostSubject: Re: 1999 riviera sc3.8 no start, help!!   1999 riviera sc3.8 no start, help!! EmptyTue Mar 26, 2013 10:55 pm
Hard to say.....but WELCOME!I believe we'll think of something .
Merit : 153
PostSubject: Re: 1999 riviera sc3.8 no start, help!!   1999 riviera sc3.8 no start, help!! EmptyWed Mar 27, 2013 3:22 am
Check for break in cam and crank sensor wiring inside the insulation at the sensor connector. Check for unrelated issue - wiring harness failure at the firewall connector. Backtrack your repairs.
PostSubject: Re: 1999 riviera sc3.8 no start, help!!   1999 riviera sc3.8 no start, help!! EmptyWed Mar 27, 2013 8:50 am
Albert,
I found Luis over at www.buickforums.com, and steered him over here. I did suggest he check the harness connection at the firewall, and even linked him to the cam sensor CEL thread. Hopefully, that is the key to his problem as he replaced some pulleys, and disconnected the mount. Maybe that stressed some some of the wiring if the engine position dropped due to the disconnected mount.
http://www.buickforums.com/forums/showthread.php?t=30421
Merit : 153
PostSubject: Re: 1999 riviera sc3.8 no start, help!!   1999 riviera sc3.8 no start, help!! EmptyWed Mar 27, 2013 11:46 am
@Larry: my guess is its most likely a bad splice in the replacement harness, possibly a bad crimp in a connector (those are real difficult to find and fix), maybe a hidden break in the ckp wiring, and if Luis went to the wrong parts store - a ckp that was bad new.
PostSubject: Re: 1999 riviera sc3.8 no start, help!!   1999 riviera sc3.8 no start, help!! EmptyWed Mar 27, 2013 7:09 pm
albertj wrote:
@Larry: my guess is its most likely a bad splice in the replacement harness, possibly a bad crimp in a connector (those are real difficult to find and fix), maybe a hidden break in the cop wiring, and if Luis went to the wrong parts store - a ckp that was bad new.
Well, if anyone can help, it's here. Hope he gets it sorted out.
Merit : 153
PostSubject: Re: 1999 riviera sc3.8 no start, help!!   1999 riviera sc3.8 no start, help!! EmptyWed Mar 27, 2013 11:22 pm
I hope so too. I suspect some people can find the advice from this board to be frustrating at first because the answers are questions early on.
» Brisbane Track Class 11/02/11 Start Lists
» False start rule causes problems when applied sporadically
» Paris Diamond League - July 8th Provisional START LISTS
» False start rule makes athletes edgy for USA Champs
