| Write-Up: Changing Supercharger Oil | |
+37joshuadalegrimes 96_Juggernaut IFallsRon charlieRobinson manofmany scrhodes4942 carlos flyineagle96 Abaddon GMFreak8 24198tom fieromanie DEMonte1997 Eldo robotennis61 Rickw L67 98inSFl albertj Ironclad-454 95RiviSC Ash 98RiviSC curious riv AA vendetta deekster_caddy 1wickedninja akasirro ibmoses Mr.Riviera 99Rivman SpaceBar ¤DoughBoy¤ 1998 Riv Fuzzy mayfair4life187 41 posters |
| Subject: Re: Write-Up: Changing Supercharger Oil Tue Jan 18, 2011 3:16 pm | |
| Well, the fatty acids definitely explain the rotten cheddar smell... | |
flyineagle96 Junkie
| Subject: Re: Write-Up: Changing Supercharger Oil Tue Jan 18, 2011 3:39 pm | |
| Dam that shit, sure does smell like "ass"!!!! Hey,maybe we should put a used bottle, in the DUMP THREAD, so people can smell it.... | |
carlos Rookie
Name : carlosfuentes Joined : 2010-07-26 Post Count : 11 Merit : 0
| Subject: temp Tue Apr 26, 2011 12:30 pm | |
| I can put the motor oil in the supercharged is that I live in mexico but here in my city can not find the special oil? | |
| Subject: Re: Write-Up: Changing Supercharger Oil Tue Apr 26, 2011 12:35 pm | |
| Ay caramba! What year is your car? | |
carlos Rookie
| Subject: Re: Write-Up: Changing Supercharger Oil Tue Apr 26, 2011 3:03 pm | |
| another type of oil that can carry the SC, is that where I live is impossible to find the special oil, I live in mexico?
HELPPPPPPPPPP | |
carlos Rookie
| Subject: Re: Write-Up: Changing Supercharger Oil Tue Apr 26, 2011 3:04 pm | |
| MY CAR IS THE BUICK RIVIERA 96 SUPERCHARGED | |
| Subject: Re: Write-Up: Changing Supercharger Oil Tue Apr 26, 2011 3:24 pm | |
| go to ,Rockauto.com you can order from them | |
| Subject: Re: Write-Up: Changing Supercharger Oil Tue Apr 26, 2011 6:54 pm | |
| summit racing also carries gm supercharger oil for like $9 a bottle. that is what most gm dealers will charge you after the loyalty discount. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: Changing Supercharger Oil Tue Apr 26, 2011 8:02 pm | |
| Carlos, do you have any General Motors dealers in your area? In general, any GM dealer can order parts for any Buick, Olds, Chevy, etc...
The supercharger oil is part #12345982, and you need 2 bottles. | |
scrhodes4942 Special
Name : Scott Location : IL Joined : 2011-10-12 Post Count : 3 Merit : 0
| Subject: Supercharger oil change cost... Thu Oct 13, 2011 8:18 am | |
| What can I expect to pay to have the oil changed on the Supercharger on my 98 Riv? I am taking it to a GM dealer. Thanks | |
| Subject: Re: Write-Up: Changing Supercharger Oil Thu Oct 13, 2011 8:28 am | |
| When I was at the dealer, we charged 1.0 labor ($90), and it's around $35-$40 for 2 bottles of oil. You're looking at about $130 total.
You're better off renting a vacuum pump from the parts store and doing it yourself. It's a simple job to do.... | |
| Subject: Re: Write-Up: Changing Supercharger Oil Thu Oct 13, 2011 8:39 am | |
| - scrhodes4942 wrote:
- What can I expect to pay to have the oil changed on the Supercharger on my 98 Riv? I am taking it to a GM dealer. Thanks
Do it yourself man! dont miss this opportunity to get close and personal with your Riv.I'm not supposed to tell you this but...when you get close and personal with a Riv,you join a secret society of druids.secrets of the universe will later be revealed to you.................... | |
| Subject: Re: Write-Up: Changing Supercharger Oil Thu Oct 13, 2011 8:59 am | |
| Robo, we've told you to stop huffing the bug spray dude..... | |
| Subject: Re: Write-Up: Changing Supercharger Oil Thu Oct 13, 2011 9:18 am | |
if you buy 2 bottles of SC oil, then go to a dollar store and get a "turkey baster" (just ask they'll know and they'll likely have 'em) you can change the oil yourself. - park the car **level** (so you don't goof emptying or filling the SC) - SC oil bung plug is at base of SC snout - try taking the plug out with allen wrench (if it is not in too tight a Torx will work bUT risks stripping) - if plug is "stuck" warm up the car then take it out (usually when warm it comes out easy, plug is steel SC is a light alloy) - suck out SC oil and discard per local regulations (if no local regs, use crumpled newspaper in a trash bag to soak it all up. Warning, it really smells bad) - pour in replacement SC oil, til the oil level is at bottom of the threads of the SC oil check/fill hole - replace SC oil bung plug. If it is any comfort to you if you have your oil changes at a GM dealer they are supposed to check and top off the SC oil. This is hit-or-miss. At my dealer I find it depends on which mechanic does the OC. So unless I am overdue for the OC I just do it myself and check the SC fluid then. If I am overdue and in the dealer for other reasons (I consult to a client near one dealer) I will have dealer do OC. And check SC fluid. | |
| Subject: Re: Write-Up: Changing Supercharger Oil Thu Oct 13, 2011 10:03 am | |
| A link with step-by-step pictures is on page 1 of this thread, if you need visual reference. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: Changing Supercharger Oil Thu Oct 13, 2011 6:02 pm | |
- A link with step-by-step pictures is on page 1 of this thread, if you need visual reference.
Just be sure you don't drink the stuff, or fry your chicken in it. | |
| Subject: Re: Write-Up: Changing Supercharger Oil Thu Oct 13, 2011 6:08 pm | |
| - Abaddon wrote:
- Robo, we've told you to stop huffing the bug spray dude.....
I hear ya buddy,its just that huffin the S/C oil got too expensive | |
manofmany Addict
| Subject: Re: Write-Up: Changing Supercharger Oil Thu Oct 13, 2011 9:23 pm | |
| - Abaddon wrote:
- When I was at the dealer, we charged 1.0 labor ($90), and it's around $35-$40 for 2 bottles of oil. You're looking at about $130 total.
You're better off renting a vacuum pump from the parts store and doing it yourself. It's a simple job to do.... 1 hour minimum I assume? That's a complete rip-off. Hell, that's what I paid to have my heater core changed out. | |
| Subject: SC Oil change... Sat Oct 15, 2011 4:10 pm | |
| Took to local Buick dealer $60.00. Worth it to me. Thanks for your advice. | |
| Subject: Re: Write-Up: Changing Supercharger Oil Mon Oct 17, 2011 8:22 am | |
| - manofmany wrote:
- 1 hour minimum I assume? That's a complete rip-off. Hell, that's what I paid to have my heater core changed out.
No minimum, just an hour + parts. That's what the labor time is to do that job according to GM's labor guide. | |
| Subject: Re: Write-Up: Changing Supercharger Oil Mon Oct 17, 2011 10:39 am | |
| - Abaddon wrote:
No minimum, just an hour + parts. That's what the labor time is to do that job according to GM's labor guide. An hour is a bit rich, you think? Albertj | |
| Subject: Re: Write-Up: Changing Supercharger Oil Mon Oct 17, 2011 10:45 am | |
| Wasn't my call dude. They came in with a Repair Order....I just did the work. The Service Advisors wrote 'em up. Doing that whole job, parts and labor, for $60 is cheap IMO. I'd be surprised if 2 bottles made it in to the S/C for that..... | |
| Subject: Re: Write-Up: Changing Supercharger Oil Mon Oct 17, 2011 11:32 am | |
| - Abaddon wrote:
- Wasn't my call dude. They came in with a Repair Order....I just did the work. The Service Advisors wrote 'em up.
Doing that whole job, parts and labor, for $60 is cheap IMO. I'd be surprised if 2 bottles made it in to the S/C for that..... It's hard to tell sitting here. On the one hand GM dealer cost on SC oil is not what a consumer or even a jobber sees. On the other had they could easily have cut corners on the job (topped off the oil). Given what they *could* do even $60 is a bit rich but not unrealistic given dealership overhead (high). The dealership I go to, if I pay them for an oil change they check and top off the SC oil included. However they charge almost $50 for an oil change unless you're in the customer card program -- and then they slide the charge depending on your business volume. I don't know really what they charge to change just the SC oil. It might be one of those "pick a number" things. Or the service manager spins the bingo cage in his office and charges 3x the number of the ball that drops out?!? ! (JK) again, I dunno... Albertj | |
| Subject: Re: Write-Up: Changing Supercharger Oil Mon Oct 17, 2011 7:58 pm | |
Doing that whole job, parts and labor, for $60 is cheap IMO. I'd be surprised if 2 bottles made it in to the S/C for that..... Invoice states: "Two bottles of SC Oil and .5 hour labor" | |
charlieRobinson Expert
| Subject: Re: Write-Up: Changing Supercharger Oil Tue Dec 18, 2012 8:07 pm | |
| - robotennis61 wrote:
- Do it yourself man! dont miss this opportunity to get close and personal with your Riv.I'm not supposed to tell you this but...when you get close and personal with a Riv,you join a secret society of druids.secrets of the universe will later be revealed to you....................
Pledging to do this before the New Year. The hub and the MPS hub with a 3.6" too. And real excited to get a whiff of this SC fragrance everyone raves about. Can't wait to learn the secrets of the Universe. | |
| Subject: Re: Write-Up: Changing Supercharger Oil | |
