 A/C Louder than anything
5 posters
Mason
A/C Louder than anything Empty
PostSubject: A/C Louder than anything   A/C Louder than anything EmptyWed May 22, 2013 5:29 pm
Recently I hit some railroad tracks a bit too fast. Ever since this "bump" my car has sounded different when idling/ low rpms. No performance issues. Recently found out that after I hit this bump my AC stopped working! No cold air. It seems to be getting worse, now there is a metallic sound at all low rpms as if something is scraping constantly and chirping etc. Any ideas? need a new AC unit?
PostSubject: Re: A/C Louder than anything   A/C Louder than anything EmptyWed May 22, 2013 7:51 pm
The first thing you should do is to check the AC compressor and belt to see if you knocked something loose. I wouldn't drive it too much before you find out what is broken and needs to be fixed.
PostSubject: Re: A/C Louder than anything   A/C Louder than anything EmptyWed May 22, 2013 10:22 pm
Could be a lot of things. I might guess physical damage to the A/C clutch.
Mason
PostSubject: Re: A/C Louder than anything   A/C Louder than anything EmptyThu May 23, 2013 6:27 pm
I got it lifted and am looking around. Nothing looks damaged. I can spin the compressor without moving the belt a bit, is this supposed to happen?
A/C Louder than anything S7XCVE8
I can spin this fairly easily with some roughness to it besides the pulley with belt
PostSubject: Re: A/C Louder than anything   A/C Louder than anything EmptyThu May 23, 2013 6:41 pm
You're spinning the clutch, not the compressor. If the clutch was engaged, you wouldn't be able to turn it, period. Judging by all the what appears to be belt fibers and goo, it looks like that compressor has issues...and it should spin FREELY when not engaged, not rough.
Mason
PostSubject: Re: A/C Louder than anything   A/C Louder than anything EmptyThu May 23, 2013 6:57 pm
Makes sense. Yeah it's very-not-free-spinning. Sand-papery. Is there an easy way to take the clutch off to have a look at it?
PostSubject: Re: A/C Louder than anything   A/C Louder than anything EmptyThu May 23, 2013 10:27 pm
Personally, I've never taken one apart. We (at work) just replace the entire compressor. I know there's a way to service it, but I can't say exactly how....
Mason
PostSubject: Re: A/C Louder than anything   A/C Louder than anything EmptyMon May 27, 2013 11:12 pm
Took the belt off, the pulley is rough spinning and it's got way too much play. Don't plan on keeping the car too much longer so I'm just getting a bypass pulley in on wednesday. Prep work? Anything I should know as far as bleeding the system goes
PostSubject: Re: A/C Louder than anything   A/C Louder than anything EmptyMon May 27, 2013 11:57 pm
I didn't know they made a bypass pulley for the 95?sure it's gonna work?
Mason
PostSubject: Re: A/C Louder than anything   A/C Louder than anything EmptyTue May 28, 2013 4:09 pm
Apparently the ones for the newer versions fit just need a washer for each of the bolts
» fuel injectors ticking louder then norm.
