| bearing noise | |
highwaywarrior Fanatic
 | Subject: bearing noise Sat Sep 28, 2013 8:59 pm | |
| Straight to the point:
1. I only hear this noise when the car is warmed up. 2. Its comingfrom the left side of the engine (passenger) 3. Used a giant screwdriverto listen to supercharger, waterpump, and alt. (Couldntreach powersteering.) 4..waterpump seems to be significantly louder that the alt and sc. 5 as ive said I only hear it while driving and the cars warmed up to operating temperature. Better still, I hear it while accelerating, not at idle.
Tips? Clues | |
 | Subject: Re: bearing noise Sun Sep 29, 2013 12:10 am | |
| Try taking off the S/C belt and see if the noise goes away. will rule out about half the bearing that normally go bad. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18440 Merit : 248
 | Subject: Re: bearing noise Sun Sep 29, 2013 12:22 am | |
| It's probably one of the accessory pulleys. Could be a tensioner or idler pulley. Remove belts and turn/wiggle each pulley to check for squeaks/slack. Good luck. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: bearing noise Sun Sep 29, 2013 1:03 am | |
| I took one belt off ata time. First the supercharger, still heard the noise. Then the accessory belt....still heard the noise. I did notice a noisefrom the powersteering, but its a completely different noise... sounds like its coming from within the engine | |
 | Subject: Re: bearing noise Sun Sep 29, 2013 9:35 am | |
| If its a sort of whining sound, like power steering, it could be the oil pump in the transmission. When old, the seals inside the trans can become leaky when warm. The pump works harder, so makes noise - or so I've been told. Mine did that for 50k or so before rebuild. Not much I could do about it. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: bearing noise Sun Sep 29, 2013 10:55 am | |
| Yes! Exactly, sounds like powersteering, but from elsewhere. I rev it neutral when warmed up, I hear it too, like a whirring powersteeering noise. How would a bearing gone bad in the engine sound? | |
 | Subject: Re: bearing noise Sun Sep 29, 2013 11:27 am | |
| If it's the trans it should come from driver side more than passenger. I was thinking harmonic balancer, but that's more of a knocking sound, and would cause vibration. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: bearing noise Sun Sep 29, 2013 12:07 pm | |
| I guess I will stick a screw driver to the trans and hsve a listen | |
 | Subject: Re: bearing noise Sun Sep 29, 2013 12:51 pm | |
| Check this out http://www.freeasestudyguides.com/a2_2.html regarding the noise I may be hearing | |
h20man Enthusiast
Name : Aaron W. Age : 29 Location : CT Joined : 2013-10-04 Post Count : 242 Merit : -2
 | Subject: Re: bearing noise Fri Oct 11, 2013 1:04 pm | |
| im hearing the same noise from my car, almost sounds like sand, could be the coupler but sounds like its coming from the transmission any ideas what it could be? | |
 | Subject: Re: bearing noise Fri Oct 11, 2013 1:14 pm | |
| Difficult to say if it's the same noise, based on the descriptions given.
Shifting into N or P may rule out the transmission.
Turning off engine while rolling off may rule out engine and supercharger.
If it's audible will idling in park, a mechanic's stethoscope can help pinpoint the exact source of the noise. You may be surprised to find the sound isn't coming from where you think, or it could be exactly where you think. Trick is to be sure before you go changing things. This avoids extra cost and the risk of causing more damage. Best of luck.
 | Subject: Re: bearing noise  | |
| bearing noise | |
