 help car not running right at all...
2 posters
bmcd9179
bmcd9179
help car not running right at all... Empty
PostSubject: help car not running right at all...   help car not running right at all... EmptyTue Oct 22, 2013 12:43 am
Hi guys i just changed the supercharger oil. filled it to the top of the threads. In the process i pulled the spark plug wires out of the connector to get them out of the way. forgot about them, when i started the car it wasnt running right so i turned the car off pluged the wires back in and the car is running so bad, the engine shakes like its having a misfire, so i checked the spark plugs and there all good, anyone know whats happening? and the supercharged belt churps. i dont know what to do guys so help asap this car is my baby. and i dont think my wires are in the right number spots does anyone know how the wires go in order from the spark plug to the connector. cause that could be the problem i hope.
PostSubject: Re: help car not running right at all...   help car not running right at all... EmptyTue Oct 22, 2013 1:12 am
help car not running right at all... B1FB5151-B899-4463-B1DC-1471BD852871-15027-00000C004A5F7E55_zpsd94f5b7e
Here is the cylinder numbering so you can be sure you ran the plug wires correctly.
bmcd9179
bmcd9179
PostSubject: Re: help car not running right at all...   help car not running right at all... EmptyTue Oct 22, 2013 1:27 am
Got it!! Thank you so much it's running so good, thank you so much I was worried I got a rod nock.. Thanks again!
» FAQ: Engine Coolant Temperature & Fan Turn-On
» FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting
» SES and running cold
» 96 n/a riv that will not stay running
» Alternator Failure, Voltage Spike!
