 Zzp stock air box K&N filter
bmcd9179
6 posters
bmcd9179
bmcd9179
Zzp stock air box K&N filter  Empty
PostSubject: Zzp stock air box K&N filter    Zzp stock air box K&N filter  EmptyWed Jan 15, 2014 12:25 am
Hi guys I want to get a stock air box filter from zzp, is it worth it? Will it fit in my 96 because it only lists 97 and up
PostSubject: Re: Zzp stock air box K&N filter    Zzp stock air box K&N filter  EmptyWed Jan 15, 2014 12:47 am
It's just a K&N panel. They list it as 95-97 actually. All years are the same, so it should fit. Is it worth it? I suppose. You're paying $50 for a K&N. You can go to the local parts store and pay the same. You can also take your OEM filter in with you to make sure the K&N matches it.
bmcd9179
bmcd9179
PostSubject: Re: Zzp stock air box K&N filter    Zzp stock air box K&N filter  EmptyWed Jan 15, 2014 12:58 am
Ok sounds good thanks AA, I'll probably go to the local parts store and get one, and make sure I match it right, and by the way, I read your engine rebuild, I would kill to do that to my engine, amazing!
PostSubject: Re: Zzp stock air box K&N filter    Zzp stock air box K&N filter  EmptyWed Jan 15, 2014 10:55 am
Is it worth it? Personally, I don't feel it is. What are you gaining on the street? You may save some $ over a paper filter if you clean and re-use it long enough. Don't over-oil it though. Too much oil and it can wind up on the MAF sensor and screw things up. I used one for a year or 2 then sold it. Of course I'm an old fart now and the less complicated and time consuming, the better, imho. If you want to mess around with cleaning and oiling, go right ahead.
PostSubject: Re: Zzp stock air box K&N filter    Zzp stock air box K&N filter  EmptyWed Jan 15, 2014 10:58 am
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
I haven't read thru this yet, but looks like some good info.
Just read thru it, and I'll stick with my AC Delco filter...
PostSubject: Re: Zzp stock air box K&N filter    Zzp stock air box K&N filter  EmptyWed Jan 15, 2014 12:03 pm
The odds are you won't notice a huge difference going to a K&N panel filter. Maybe a few hp. You will get more HP from gutting the box or installing a CAI or FWI.
bmcd9179
bmcd9179
PostSubject: Re: Zzp stock air box K&N filter    Zzp stock air box K&N filter  EmptyWed Jan 15, 2014 9:48 pm
Yah it's 50+$$ when I can get stuff for a little bit more for a CAI set up and get better horsepower and louder supercharger, I'll read more on that, I'm to addicted to the supercharger whine!!!
h20man
h20man
Merit : -2
PostSubject: Re: Zzp stock air box K&N filter    Zzp stock air box K&N filter  EmptyThu Jan 16, 2014 12:33 am
i was able to make a 4in fenderwell intake using pvc piping for about 80 bucks, including the k&n cone filter
96_Juggernaut
96_Juggernaut
Name : Todd Balestrini
PostSubject: Re: Zzp stock air box K&N filter    Zzp stock air box K&N filter  EmptyThu Jan 16, 2014 9:19 pm
I originally had a K&N panel filter and did not truly notice a difference until I went with the 4" aluminum cold air intake. I think the intake air temp is more of a factor to the L67 and m90 over air flow.
» Stock 99 Riv timing Vs. Similar Stock Timing Tunes
» PF 52 oil filter?
» Choosing a filter
» Write-Up: Fuel Filter Replacement
» FAQ: Fuel Filters
