 Rear Wheel Hub/Bearing Replacement
4 posters
Yardley
Rear Wheel Hub/Bearing Replacement Empty
PostSubject: Rear Wheel Hub/Bearing Replacement   Rear Wheel Hub/Bearing Replacement EmptyMon Jan 20, 2014 10:57 pm
I see there is a write-up on replacing the front hubs/bearings, but how difficult is it to replace the rears?
http://www.1badriv.com
PostSubject: Re: Rear Wheel Hub/Bearing Replacement   Rear Wheel Hub/Bearing Replacement EmptyTue Jan 21, 2014 12:14 am
I believe this is the correct procedure (for 95 at least) Correct me if wrong anyone!
Yeah edit, linked wrong vid. Sigh....phones
Below is the one I thought was linking
PostSubject: Re: Rear Wheel Hub/Bearing Replacement   Rear Wheel Hub/Bearing Replacement EmptyTue Jan 21, 2014 1:12 am
The Riv has 4-Wheel discs. Should be very similar to this here because the brakes are even interchangeable with the 97-99 Rivs.
PostSubject: Re: Rear Wheel Hub/Bearing Replacement   Rear Wheel Hub/Bearing Replacement EmptyTue Jan 21, 2014 1:20 am
well,the 95 Rivs dont come with drum brakes but yeah,essentially the same...
Yardley
PostSubject: Re: Rear Wheel Hub/Bearing Replacement   Rear Wheel Hub/Bearing Replacement EmptyTue Jan 21, 2014 7:13 am
Simple R&R. Thanks gang!
