| My car it's too high in both the front and rear | |
carguy8888 Addict
Name : Brian Cohen Joined : 2019-01-07 Post Count : 545 Merit : 1
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 6:47 pm | |
| I'm sure I don't have this rancho shock mod. It looks like it could have been a discontinued AC Delco part number. I don't mind buying a set of stock coil springs and having them installed, I'm just afraid I may have the same problem and then I wasted ,$300. | |
carguy8888 Addict
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 7:03 pm | |
| Larry, maybe I'm getting lost in the type, I need help with the front not the rear and it does say on that post that they are discontinued. | |
Name : Larry Age : 64 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 1930 Merit : 128
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 7:09 pm | |
| - carguy8888 wrote:
- Larry, maybe I'm getting lost in the type, I need help with the front not the rear and it does say on that post that they are discontinued.
Well, you are talking about a shock, and we only have shocks in the rear, the fronts are struts. That's why I was confused. I thought you might already have the Ranchos. I looked for you at Bellmore Friday, but all I saw was a 1999 Riviera. Thought it might be you. His car looked too high all around, but he had P225/50R-17, and they are 3/4" shorter, so the wheel wells weren't filled. The car looked stupid. | |
carguy8888 Addict
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 7:14 pm | |
| That was not me because I have 16" but I feel my car looks stupid as well. so if the front is struts and somebody has to be willing to either cut them or I have to buy new struts and pray they are right height? | |
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 7:32 pm | |
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 7:34 pm | |
| I actually kept the old struts for awhile, but I junked them about 6 months ago. If I still had them, I would have removed the springs and given them to you.
The Ready Struts are easy to install. I did it myself. | |
carguy8888 Addict
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 7:37 pm | |
| Basically I should just wait and do the Gabriel ready struts is what you're saying? | |
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 7:40 pm | |
| Unless someone can send you some used coil springs from a strut change? You'll have to disassemble your struts to install them. If you install the ready struts and do it yourself, it will be 200.00 + shipping. Your choice. | |
carguy8888 Addict
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 8:04 pm | |
| It will be $350 because I'm not able to install them myself. | |
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 8:24 pm | |
| - carguy8888 wrote:
- It will be $350 because I'm not able to install them myself.
That's too bad. I try to do everything my self on both cars. Sometimes though, you have to bring it to a shop. | |
carguy8888 Addict
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 8:29 pm | |
| I have no access to a lift, I am in the city, and I'm smart enough to know if I want it done correctly somebody else should do it. Sure wish I could cut the coils on the strut but I guess I'll wait a little bit and just replace the units.
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 8:39 pm | |
| - carguy8888 wrote:
- I have no access to a lift, I am in the city, and I'm smart enough to know if I want it done correctly somebody else should do it. Sure wish I could cut the coils on the strut but I guess I'll wait a little bit and just replace the units.
I did mine with nothing more than a floor jack. It doesn't matter though, it's a bad idea to cut the springs. Number one, you wouldn't know how much to cut off, and two, you need to remove them from the strut. To do that, you need a coil spring compressor and an impact wrench. The ready struts are easy to install. Two big bolts at the bottom, and 3 studs at the top. | |
carguy8888 Addict
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 8:40 pm | |
carguy8888 Addict
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 8:50 pm | |
| If they are good enough for you they'll be good enough for me then. | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8067 Merit : 167
 | Subject: Re: My car it's too high in both the front and rear Sun Jun 21, 2020 10:41 pm | |
| - carguy8888 wrote:
- If they are good enough for you they'll be good enough for me then.
In my experience, the first week or 2 they will ride a little jiggly but after that they settle in marvelously. | |
carguy8888 Addict
 | Subject: Re: My car it's too high in both the front and rear Sun Feb 07, 2021 3:59 pm | |
| - carguy8888 wrote:
- I finally had my Gabriel struts and axles installed. The passenger side axle was bad and the driver side strut unit was bent. Notice the one in the back of the picture is tilted and the spring coils are much thicker. It looks like the units that came out were OE Spectrum by Monroe but it is hard to tell. The front sits at least 1" lower and has mot settled yet. I have not gone far but it feels firmer and better.
I think you will be happy with the Gabriels...
carguy8888 Addict
 | Subject: Re: My car it's too high in both the front and rear Sun Feb 07, 2021 4:05 pm | |
| A definite improvement. Both you and Larry said go with the Gabriel's so I did not need any more convincing than that. I also went with the the axles you suggested. The parts were hanging around since Thanksgiving for me to have them installed. | |
 | Subject: Re: My car it's too high in both the front and rear  | |
