dreww Junkie
| Subject: reflectix adhesive? Sat Jul 21, 2007 4:18 am | |
| anyone got any ideas what I can use to get reflectix to stick to my airbox?
I need something that won't lose its adhesiveness with all the heat it will be exposed to. | |
| Subject: Re: reflectix adhesive? Sat Jul 21, 2007 11:21 am | |
| Does it not have it's own adhesive? If the airbox is clean, it should stick. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
dreww Junkie
| Subject: Re: reflectix adhesive? Sat Jul 21, 2007 4:55 pm | |
| it doesnt have it own adhesive....but it seems to stick fairly well to itself. Almost like my static electricity.
I will give it a try. I dont think it will stick to the intake tube though, since its not smooth surfaced like the actual airbox.
maybe use rubberbands or clamps to hold it around the intake tube? | |
| Subject: Re: reflectix adhesive? Sat Jul 21, 2007 6:44 pm | |
| you could use a high temp glue but it would be permanent. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
dreww Junkie
| Subject: Re: reflectix adhesive? Sun Jul 22, 2007 4:18 am | |
| - Mr.Riviera wrote:
- you could use a high temp glue but it would be permanent.
well, permanent is kinda the point. Thanks, I'll see what autozone has. | |
| Subject: Re: reflectix adhesive? Sun Jul 22, 2007 9:51 pm | |
| Contact cement. Follow instructions. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: reflectix adhesive? Fri Jul 27, 2007 2:59 pm | |
| Subject: Re: reflectix adhesive? | |
