| Squeeky | |
+6jax95riv AA Mr.Riviera jimmyriv Jason sqeeky 10 posters |
sqeeky Special
Age : 46 Joined : 2007-08-14 Post Count : 3 Merit : 0
| Subject: Squeeky Tue Aug 14, 2007 1:41 pm | |
| I just had a new alternator put in a 97 Riviera. I also had the serpentine belts replaced and the tension adjuster. The car makes a squeaking sound similar to chirping. Does anyone have an idea what is causing this? Thanks for the help. | |
Jason Aficionado
Name : Jason Age : 41 Location : Comox, BC, Canada Joined : 2007-01-23 Post Count : 1378 Merit : 66
| Subject: Re: Squeeky Tue Aug 14, 2007 1:44 pm | |
| welcome to the forum. We'll need more info on your car. Mileage? Have the idler AND tensioner pulleys been changed ?
My father's GTP and gf's 98 regal gs' pulleys started squeaking at about 70k miles. Members have reported pulley failure at approx 85k miles. They are cheap and easy to change, except the lower supercharger idler on the G-bodies (the riviera is a g-body). | |
jimmyriv Junkie
Name : James Age : 80 Location : Muskegon, Michigan Joined : 2007-03-16 Post Count : 781 Merit : 8
| Subject: Re: Squeeky Tue Aug 14, 2007 2:15 pm | |
| Welcome to the forum, sqeeky........ | |
| Subject: Re: Squeeky Tue Aug 14, 2007 2:48 pm | |
| welcome! my water pump started squeeking at 120k miles. you should take off the s/c belt and see if the noise goes away. that will isolate which area is failing. but like jason said, our pulleys seem to all go out at the same mileage (~90k) _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Squeeky Tue Aug 14, 2007 3:06 pm | |
| I got a minor chirp after replacing my belts, too. It only lasts a few seconds when I start up. Does yours happen all the time? Does it only chirp, or is it more of a grinding/whining sound? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
jax95riv Aficionado
| Subject: Re: Squeeky Tue Aug 14, 2007 4:44 pm | |
99Rivman Aficionado
Name : Randall Location : North Carolina Joined : 2007-01-16 Post Count : 2009 Merit : 90
| Subject: Re: Squeeky Tue Aug 14, 2007 8:48 pm | |
| Welcome! I've not had that problem with either of mine yet, sorry I'm of no help here. | |
SpaceBar Aficionado
Name : Patrick Age : 38 Location : Quincy, MA Joined : 2007-04-08 Post Count : 1199 Merit : 3
| Subject: Re: Squeeky Tue Aug 14, 2007 9:16 pm | |
sqeeky Special
| Subject: Re: Squeeky Tue Aug 21, 2007 1:47 pm | |
| Thanks for all of the help! The car has about 103k miles. The car is also supercharged. The car seems to chirp when I first turn the car on. It also chirps while driving while driving. Thank again everyone for the help. | |
98riv Moderator
| Subject: Re: Squeeky Tue Aug 21, 2007 2:20 pm | |
| Welcome to the forum! I would make sure the belt is on correctly and check all of the pulleys are installed correctly and are in good shape. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
1998rivman Amateur
| Subject: Re: Squeeky Tue Aug 21, 2007 2:41 pm | |
| Welcome!
One question...Was it squealing before the alternator was replaced? The reason I ask is that I was about to replace my alternator due to squeaks and squeals and then noticed the telltale weeping from below the W/P. It was my water pump all along. No noise since. | |
| Subject: Re: Squeeky Tue Aug 21, 2007 7:05 pm | |
| - 1998rivman wrote:
- Welcome!
One question...Was it squealing before the alternator was replaced? The reason I ask is that I was about to replace my alternator due to squeaks and squeals and then noticed the telltale weeping from below the W/P. It was my water pump all along. No noise since. exact same senario here _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
sqeeky Special
| Subject: Re: Squeeky Thu Aug 23, 2007 12:37 pm | |
| It actually all started when I was driving one day, and my power steering locked up. The engine started to over heat. I quickly pulled over the car. The serpentine belt broke, and had been ripped to shreads. I had to replace the alternator. I then had one of the tenioners replaced.
I had the belt replaced several times, the last time with a belt designed for the riviera. Stil a chiping sound. Alas.... this is my story. | |
| Subject: Re: Squeeky | |
| Squeeky | |
