| L67 head porting | |
![1998 Riv](https://2img.net/u/3215/30/10/37/avatars/6-66.jpg)
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: L67 head porting Fri Sep 07, 2007 11:33 am | |
| Greg Gessler is a well-known and highly reputable head/manifold porting specialist in the Buick community, but I didn't know he did 3800 projects too. Here's a link to his head porting page, priced for different levels of work, from stock to strip.
http://www.gesslerheadporting.com/members/gesslerheadporting/ghp.nsf/top-menu-items/ghp03 | |
![Go down](https://2img.net/i/empty.gif) | |
97rivman Fanatic
![97rivman](https://2img.net/u/3215/30/10/37/avatars/158-44.jpg)
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting Fri Sep 07, 2007 11:41 am | |
| thats not too bad of a price, but for the same price, you can get Intense heads. I port and polished my own heads and got bigger valves that will defiantly outdo whatever he does....but Im never ever in a million years doing it again unless Im getting paid $1000. | |
![AA](https://2img.net/u/3215/30/10/37/avatars/1-6.jpg)
Name : Aaron Age : 47 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18448 Merit : 252
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting Fri Sep 07, 2007 12:02 pm | |
| Good find. Price isn't too bad for what it is, but still... quote: "The Level 2 heads are recommended for a horse power increase on a budget.... $1050.00... with core exchange."I could install an IC for less. ![neutral](https://2img.net/i/fa/i/smiles/icon_neutral.gif) _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ ![frown](/users/3215/30/10/37/smiles/icon_sad.gif) | |
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting Fri Sep 07, 2007 4:32 pm | |
| For sure, head porting is never cheap when you pay someone else to do the work. Very labor-intensive, and expensive equipment needed to do the job right. | |
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting Fri Sep 07, 2007 4:41 pm | |
| It's one of those mods you just pay for unless you really know what you're doing, which I don't. If I were getting it done, would have to go Stage III. Only $700 more to have the best, and all the work of tearing the heads off...might as well. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ ![frown](/users/3215/30/10/37/smiles/icon_sad.gif) | |
97rivman Fanatic
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting Fri Sep 07, 2007 5:00 pm | |
- It's one of those mods you just pay for unless you really know what you're doing, which I don't. If I were getting it done, would have to go Stage III. Only $700 more to have the best, and all the work of tearing the heads off...might as well.
I didnt know what I was doing aside from grinding concrete and other metals for work with HD tools....But I went through 3 dremels and very steady hands and alot of coppin a feel on the CC's. Once you know what to look for when porting heads, its really easy assuming you have extreme patience because Cast iron doesnt like to grind down very easy. | |
![Jack the R](https://2img.net/u/3215/30/10/37/avatars/5-79.jpg)
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting Fri Sep 07, 2007 10:11 pm | |
| Did you do anything to increase the compression ratio for E85? | |
97rivman Fanatic
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting Sat Sep 08, 2007 12:32 pm | |
| - Jack the R wrote:
- Did you do anything to increase the compression ratio for E85?
I did the complete opposite and hogged out the CC. and put in 8.0:1 bored .010 over diamond pistons. Ill probably run a 50/50 blend for a while once I get tuning. and then go full E85. Ill eventually be pushing so much boost that the E85 will love it. I just got a 3" pulley for my GEN V so Im looking at probably 12 psi min. | |
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting Sat Sep 08, 2007 1:23 pm | |
| Agree, no need to increase compression ratio, just up the boost! More air/fuel in with lower comp ratio. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ ![frown](/users/3215/30/10/37/smiles/icon_sad.gif) | |
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting Sat Sep 08, 2007 3:08 pm | |
| I could have sworn I'd read about increased compression being used to optimize for ethanol, but you guys are right, boost will do it as well - - Quote :
- Saab Introduces E85 Turbo BioPower Engine
But E85 also has a high octane rating (around 110), and Saab realized that a turbocharger could harness it. Turbos push extra air into the cylinder, and higher octane allows a fuel to better endure the increased pressure. So Saab cranked up its fans and created the BioPower engine, the first commercially available ethanol turbo. A computer samples the fuel mixture and adjusts boost pressure—from 5.8 psi for pure gasoline to 13.8 psi for E85. Running straight gasoline, the engine produces 148 horsepower, but E85 jacks it up to 184, with no penalty in fuel economy. Link So how far can boost be pushed with the L67 before things start blowing up? | |
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting Sat Sep 08, 2007 3:18 pm | |
| I regularly see peaks of 13 PSI in cooler weather. I remember a scan from a long time ago showing 15 PSI at 6kRPM (with about 6 deg of KR) during a track run, but when I mentioned this to the guys at INTENSE, they couldn't believe it. Perhaps I was wrong in my calculations, but I didn't think I was, and can't find the scan to prove it. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ ![frown](/users/3215/30/10/37/smiles/icon_sad.gif) | |
![L67 head porting Empty](https://2img.net/i/empty.gif) | Subject: Re: L67 head porting ![L67 head porting Empty](https://2img.net/i/empty.gif) | |
