| Introducing the 3T60E-NSHD | |
+3Mr.Riviera jax95riv oldsman105 7 posters |
oldsman105 Junkie
Name : Enrique Patino Age : 39 Location : Queens, New York City Joined : 2007-01-24 Post Count : 756 Merit : 10
| Subject: Introducing the 3T60E-NSHD Wed Jan 02, 2008 9:23 am | |
3 speed T Transverse 60 series E electronic TCC lockup - N Not S so H heavy D Duty
With available speeds 1,2 and 4 with torque converter lockup.
At WOT contions you will be able to do 88 mph before you hit the rev limiter since third gear isn't available. Who needs third gear.
My car lost third gear
*end rant* | |
jax95riv Aficionado
| Subject: Re: Introducing the 3T60E-NSHD Wed Jan 02, 2008 10:16 am | |
| Bummer, that really sucks. Any extra goodies planned with the new tranny? | |
oldsman105 Junkie
| Subject: Re: Introducing the 3T60E-NSHD Wed Jan 02, 2008 4:40 pm | |
| Higher stall, ZZP shift kit... thats if I don't have to take the trans apart. If I do I may go crazy | |
| Subject: Re: Introducing the 3T60E-NSHD Wed Jan 02, 2008 5:28 pm | |
| - oldsman105 wrote:
- Higher stall, ZZP shift kit... thats if I don't have to take the trans apart. If I do I may go crazy
see Aaron, thats how you do it! j/k i'm getting scared now that everyones trannys are dying i cant hardly afford tires right now _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Introducing the 3T60E-NSHD Wed Jan 02, 2008 5:31 pm | |
| I had the INTENSE shift pak, which will stay in the newly rebuilt trans. I would like to see Aamco's reaction to the high-stall and gearing changes... "So, I still get the 12-month warranty, right?" _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Introducing the 3T60E-NSHD Wed Jan 02, 2008 5:33 pm | |
| "so do slicks void the warranty??" _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Introducing the 3T60E-NSHD Wed Jan 02, 2008 7:52 pm | |
| - Mr.Riviera wrote:
- i'm getting scared now that everyones trannys are dying
hey hey my original is not dead, just the GTP one is broken! I was swapping just for the sake of upgrading, I _could_ still put my 80k mile rebuilt back in but I'd rather improve it since it's out anyway | |
| Subject: Re: Introducing the 3T60E-NSHD Wed Jan 02, 2008 8:00 pm | |
| Wish I had an extra tranny laying around! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
BillBoost37 Junkie
| Subject: Re: Introducing the 3T60E-NSHD Thu Jan 03, 2008 6:58 am | |
- Wish I had an extra tranny laying around!
A semi local yard sells for $100 if you pull, add $75 for them to pull. There's a GP there..and I'm seriously considering pulling it. | |
RhinoFLA Aficionado
| Subject: Re: Introducing the 3T60E-NSHD Thu Jan 03, 2008 5:39 pm | |
| Subject: Re: Introducing the 3T60E-NSHD Thu Jan 03, 2008 7:29 pm | |
| it's worth $175 to have them pull it for you. It's a real PITA to get out | |
RhinoFLA Aficionado
BillBoost37 Junkie
| Subject: Re: Introducing the 3T60E-NSHD Thu Jan 03, 2008 8:36 pm | |
| - deekster_caddy wrote:
- it's worth $175 to have them pull it for you. It's a real PITA to get out
Personally my motor, trans and gas tank have been out so many times...I put them in with velcro. They come out really easy now. | |
| Subject: Re: Introducing the 3T60E-NSHD Thu Jan 03, 2008 9:10 pm | |
| you have hinges on your engine cradle? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
BillBoost37 Junkie
| Subject: Re: Introducing the 3T60E-NSHD Fri Jan 04, 2008 10:22 am | |
| - Mr.Riviera wrote:
- you have hinges on your engine cradle?
Just about. What most people don't realize is if you have a lift or enough room on the floor to the side of the car. Leave the passenger side balljoint hooked up. It's a great pivot point. | |
oldsman105 Junkie
| Subject: Re: Introducing the 3T60E-NSHD Sun Jan 06, 2008 7:10 pm | |
| Update: we got the Transmisson from the 98 regal. It had the webbing in the rear for the rivera mount!!!!!! I will be purchasing a zzp used 2750 stall converter soon. I also picked up a 97 riviera PCM and the harness that goes from the Trans to the firewall.. | |
| Subject: Re: Introducing the 3T60E-NSHD Sun Jan 06, 2008 8:12 pm | |
| don't forget for many converters you need a flexplate too! | |
oldsman105 Junkie
| Subject: Re: Introducing the 3T60E-NSHD Sun Jan 06, 2008 9:38 pm | |
| The 4T60E already has a 245mm flexplate so Im good. | |
| Subject: Re: Introducing the 3T60E-NSHD | |
