Automotive Forums > Buick > Regal - Replacing inner tie rod
http://www.automotiveforums.com/vbulletin/t624295.html "
"The inner is a PITA DIY. Instead of wasting time and possibly money trying to the replace the inner tie rod you might consider just getting a remanufactured rack and pinion unit. I do not believe it is a good idea doing the work while the rack and pinion is installed in the car but you never know."
woah this seams as if it can be much simpler
You could try it but I would recommend getting a GM service manual which will cover access, how to remove the protective boot and how it connects to the rack and any staking procedure if necessary.
"They have a flat spot on the shaft which you can use a large open end or crescent to hold it steady. This is critical as if it is turned you will have to buy a rebuilt unit. Instructions come with the inner tie rod. Check how they are held in place a pin or another way. You need a long socket as the rod is fairly long. Available at a parts store. They also have a torque spec.You can use two open ends but takes longer. Measure the number of threads left on the outer tie rod before you loosen the lock nut. Disconnect the outer tie rod and start the process. I have a tie rod bar and I check the toe in when I'm done. Mark it before you start and put it back the same way.
If you aren't careful you could easily be a 1 inch out. This puts tremendous stress on all parts. I would take two one quart oil jugs. This is for height and use a tape measure across the front of the tires center tread write this down. and when done put it back the same.
It isn't really hard but it might worry you the first time. Also inspect it before you go to the parts store as if any seals are leaking you need a rebuilt unit."
insight from enthusiasts would be appreciated
