 LeSabre Headlamps
6 posters
LeSabre Headlamps Empty
PostSubject: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 12:56 pm
ok..so i was drivin the other day and ive noticed lesabres before..theres like 10 in my neighborhood.....anyways. i noticed theyre headlights....... they look pretty similar to the rivs.. is there a way sum1 could switch em? they look a lot newer. the lesabres look like it might be a tad bigger. but im sure sum1 out there has the ability to do it.. anyone have any thoughts?
LeSabre Headlamps 1G4HR54K144175109
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 1:36 pm
I don't know... that looks like a 1 piece design. It doesn't seem likely they are the same shape.
Looking at a Riv h/l, I'd say the Riv is much shorter.
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 3:47 pm
ok then..just an idea id throw out there
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 4:03 pm
does this require a photoshop
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 4:49 pm
read agree
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 4:50 pm
will be done...coreys gonna do one
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 5:24 pm
LeSabre Headlamps 3001153674231131733IM1MA
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 5:31 pm
that looksss sooo niiiceee...IMO
Buickman104
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 6:10 pm
I'd say if you clear the corners it would look very nice on the Riv
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 6:30 pm
LeSabre Headlamps RivLasabre
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 6:32 pm
ii liikeee it on that one too!
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 6:54 pm
i agree his came out better i just did a quick one,i like it just if we could make it flow it would be nice
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 9:50 pm
It's hard to make it flow because the Riv is round, the Lesabre is square. I don't like the look, just wanted to show it from a different angle.
PostSubject: Re: LeSabre Headlamps   LeSabre Headlamps EmptyTue Mar 11, 2008 10:57 pm
I'll like my factory lights just fine, once I swap in my new corners.
LeSabre Headlamps
» '70 LeSabre 455
» FAQ: Rims, Wheels that Look Good on the Riv
» deekster_caddy's 1973 LeSabre
» Write-Up: Water Pump Change for '89 LeSabre w/ 3800
