allfalldown Member
Name : Adam Location : Renton, WA - 1996 Riv Joined : 2007-07-12 Post Count : 98 Merit : 0
 | Subject: Left rear passenger seatbelt problem Wed Apr 02, 2008 7:21 pm | |
| My left rear seatbelt is stuck "all the way out". Any info on how to fix this or get to the pully so I might fix it?
Is it a spring?
Thanks,
Adam | |
palermocorey90 Expert
 | Subject: Re: Left rear passenger seatbelt problem Wed Apr 02, 2008 7:55 pm | |
| try feeding it back in it might work. it might not its worth a shot | |
allfalldown Member
 | Subject: Re: Left rear passenger seatbelt problem Wed Apr 02, 2008 9:35 pm | |
| No, it just goes in slack. I'm not sure if there is a reset or a spring that needs to be replaced and I'm in a pinch! | |
99Rivman Aficionado
 | Subject: Re: Left rear passenger seatbelt problem Thu Apr 03, 2008 5:28 pm | |
| There was a safety recall on those for certain years. I think since it is a safety item the recall doesn't expire? You might check on that? | |
Audio72 Special
 | Subject: Re: Left rear passenger seatbelt problem Tue Jan 05, 2010 5:17 pm | |
| Has anybody checked up on this? Both of my rear seatbelts are having the same problem.
Thanks, | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8530 Merit : 181
 | Subject: Re: Left rear passenger seatbelt problem Tue Jan 05, 2010 11:05 pm | |
| check with the dealer ASAP on those stuck belts. Even if its not a recall they are not so bad.
 | Subject: Re: Left rear passenger seatbelt problem  | |
