Riviera Performance
 Write-Up: HID Conversion
firefighter
Jimdangello
Mattwa
RivieraParadise
2000ws6transam
GM FIEND
LT1Squirrel
Rizz01
tanyue123
Jayrydingslab
BigRay1125
95rivy
7901mark
TheNewEra95
Derek
KillaKeninaRiv
VJD2
BrianEsser
GMFreak8
nigelf
97 park ave
Ryan from Ohio
96RIVMANN
texasfan010
L8-2BNGO
EatDirtFartDust
manofmany
Natesriv
'96reese
NO 4 EVR
CeeKay
61 posters
Go to page : Previous  1, 2, 3 ... 11 ... 21  Next
Write-Up: HID Conversion - Page 3 Empty
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyWed Mar 26, 2008 7:36 pm
thats what i have is 6000K on the truck. i love em
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyThu Mar 27, 2008 11:31 pm
Alright, I ordered my 6000K kit! It'll probably ship out tomorrow evening, travel for Saturday, take a break on Sunday, and get here sometime next week. Expect a write-up in a new thread, and plenty of HID warmup videos!
PostSubject: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyThu Apr 03, 2008 9:14 pm
GETTING STARTED
Alright, I finally got my HID light kit!
Turns out, it wasn't a XenTec kit as advertised, and it wasn't shipped from California, but it turned out to be a package coming all the way from Shanghai. Needless to say, I inspected every bit of it when I opened the package and looked for any kinds of defects, poor quality, scratches, dents, anything. But after close inspeciton, this is a legit HID kit. All the connections had 3 rubber seals which made a tight, quality fit between connections. It came with the ballasts, lights in plastic cap enclosures to make sure they didn't get damaged, and they were even nice enough to include brackets, bolts, nuts, and washers!
I will be using the brackets for this install.
These are 6,000K lights, which are just about the best for driving. Any lower, and there's less light. Any higher, and there's more color but less useable light. The 6000K's have a nice crystal color once they're warmed up. When they start, they're very blue, and as they warm up they turn brighter and more pure white until they're perfectly white with a slight hint of blue. Everything looks exactly the same color as it would in the daytime, and that's why I recommend 6000K's for normal driving. The beauty with this kit is that once you have it installed, if you want to put in 12,000K's for show just change the bulb, but make sure they're real HID bulbs, or else your fuse and a few other things will melt!
Here's what 6000K's look like on a Charger. Note the change from blue to white:
The instructions say to make sure you use a fuse rated at 20A, as anything higher will melt. For now, here's a pic of the kit. The wires came neatly packed in the container, without stressing or sharply bending any of them, unlike how they are after I put them back in these pics, and everything has ample styrofoam padding with very thick, rigid box walls to protect them.
Write-Up: HID Conversion - Page 3 100_5755
Write-Up: HID Conversion - Page 3 100_5756
Write-Up: HID Conversion - Page 3 100_5757
Now, onto some basics!
First off, if you're doing this on a Riviera, you want the 9006 kit to replace the main headlights, and the 9005 kit to replace the brights, if you really feel a need to. I recommend 6000K color temperature, but feel free to get whatever you like. You can always buy other HID bulbs and they will work with the HID kit.
Here is what comes with the kit:
Write-Up: HID Conversion - Page 3 100_5758
-2(two) ballasts, the metal box thingies.
-2(two) mounting brackets for the ballasts.
-4(four) bolts for the brackets.
-8(eight) washers for the bolts for the brackets, four large and four small.
-2(two) lights w/ wires, I think you know what these do.
This is how they hook up:
Write-Up: HID Conversion - Page 3 100_5759
Write-Up: HID Conversion - Page 3 100_5763
Write-Up: HID Conversion - Page 3 100_5764
There are two small connectors behind the lights and coming from the ballasts. Those hook up together, with the black wires and red wires joining together. There is also a large clip that goes onto the ballast from behind the light. This clip is hard to undo, so don't start playing around like I did. There is only one way it easily fits, with the graduated metal clip on the ballast. Then there is a connector next to the light. You plug the factory light connection in here. If you can follow the current, it goes from the factory harness, down the double connectors, into the ballast, out through the large connector, and up to the light.
This is the wrong way to wire it up:
Write-Up: HID Conversion - Page 3 100_5765
To get the light out, you must unscrew(with this kit) the plastic jar it is enclosed in. The bottom must be slid all they way down, past the rubber seal and all the other clips, to get it off. It looks like this once it's out of its shell:
Write-Up: HID Conversion - Page 3 100_5761
Merit : 138
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyThu Apr 03, 2008 10:38 pm
Just cut away that gromet that they have on the wires of the bulb. That would be used if the vehicle has a sub-housing that needs to be sealed off or a custom application.
Congrats btw. You won't be disappointed!
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyFri Apr 04, 2008 6:25 am
evil IT'S RAINING. And it won't stop until early Saturday...
Oh well. Here's another tip:
Before installing the HID kit, make sure it's dry under the hood, it's not raining out, and your car has cooled down.
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptySat Apr 05, 2008 11:51 am
INSTALLING THE KIT
If you have a stock intake, you will have to remove the airbox to reach the driver's side lamp harness. To do this, undo the metal screw clamp, pull the hose leading from the box to the engine up and point it towards the windshield, take out the small sensor from the box, undo the clips at the bottom of the box towards the center of the car, and remove the box. It may be tough, but you'll get the hang of it. The passenger side light is for the most part unobstructed, so nothing has to be removed. Here are the harnesses, driver side and then passenger side. They are the little blue clips, so look for the blue in the center of the pic:
Write-Up: HID Conversion - Page 3 100_5768
After airbox removal:
Write-Up: HID Conversion - Page 3 100_5770
Pass. side, tricky to find:
Write-Up: HID Conversion - Page 3 100_5769
Write-Up: HID Conversion - Page 3 100_5766
Once you find and can reach the lamps, undo the harness. There is a clip on the top that you must push up and then pull the connectors apart. Once they are disconnected, turn the actual headlamp 90* towards the center of the car and gently pull them out. Put the stock halogens aside in case you ever have to switch back.
By the way, if you ever have to put halogens back in, you can leave the ballast in place, just disconnect the xenon lamp and store it safely away, undo the connection to the factory harness, then plug the factory harness back into the halogen bulb and put the bulb in the fixture.
I ran into a problem trying to install the lights. The wiring is straightforward and simple, but some of them have a problem with the connection to the factory harness. If your lights do not turn on, this is why! The bit of plastic on the outside that the clip fastens around is on the wrong side. Just flip it over and reconnect it and it should work. Use a 20A fuse for this install if the kit says so. The 20A works as well as the factory 10A with mine, but #1 the kit says to use the 20 and the headlight with the 20A warms up much faster than the one on the 10A.
Here is a video of my car's lights. They are awesome and well worth the time put in. The one on the passenger side is running on a 10A fuse, and the one on the driver side is running on a 20A fuse. Note how the one on the 10A fuse stays blue longer:
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptySat Apr 05, 2008 11:53 am
Sorry, forgot the tips.
Avoid turning the lights on without the engine running.
Use the fuse that the kit suggests.
Don't touch the ballasts or connections until they've cooled off. 20,000 volts is not fun.
Use common sense basically, and you'll be fine.
Merit : 138
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptySat Apr 05, 2008 12:56 pm
One note.
I have been using the original 10A fuse with my HIDs for about a year without any problem. Even if the kit suggests a 20A, stick with the 10A unless you must go higher. That's the safer rought to go.
The wiring of the car is designed to handle about 102 watts and can safely handle some more but a 10A fuse puts you at 120watts till it blows. If you go to a 20A, your talking about 240watts before it blows, in the event of a short circuit. That might be enough to be dangerous.
Under the assumption that our wiring is all the same among our rivieras, the 10A is fine. The running wattage of the HIDs is 35 which is actually less than the stock halogen, at 51. They momentarily draw more power when you switch them on but that draw is capacitated, for the most part, by the ballast.
If you want to be extra safe and do more work, you can install your own high-current wiring kit which is available at probably all auto parts stores with fuses, switch, relay, and everything you need. Downside is you have this extra button you shouldn't really need and more wiring to try to clean up.
cheers
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptySat Apr 05, 2008 11:25 pm
my only advice is; if that box gets hot keep it away from the air box.
can you aim these the same as the stock ones? how much did all this run you? any down sides to this mod besides the lights taking time to heat up? what is the life expectancy on the bulbs?
Write-Up: HID Conversion - Page 3 Dsc_0110
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptySat Apr 05, 2008 11:58 pm
They are a direct replacement for the stock bulbs, so they are pretty much aimed the same, I'd expect.
The kits go for anywhere between $125 and $140 shipped from Amazon.com. I ordered mine for $117 with $8.49 shipping for a total of $125.49
There is no real downside as long as you keep the colors down; anything over 8000K is sure to garner attention from the police. The lights heat up very quickly, in a matter of maybe 30 seconds.
Should you ever feel like showing off, you can always switch out the bulbs for other color temp. bulbs, as long as they're real, 35W HID bulbs.
When you turn them on, you'll notice the engine rpms drop then come back as the lights need extra energy to start, but then run at 35 watts instead of the stock halogen's 51 watts.
Life expectancy is >2500 hours, much longer than halogen bulbs, since there is no filament.
Here is the kit I purchased:
Link
As I said in the beginning, I did not recieve a XenTec brand kit, but these work the same and included mounting brackets.
These are what I recieved:
Link
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyMon Apr 07, 2008 9:10 pm
MOUNTING AND SECURING THE BALLASTS
I have found a very, very simple way to mount the ballasts without drilling into anything at all! No tape either! All you need is to buy a small 90* bracket with the right size holes in it for the bolts.
First off, this will not work if you have bolts that are larger than 3/8" without having to drill out a hole to a larger diameter. On both sides of the car, one above the in-hood fusebox and one above the stock airbox, there are small, hexagonal, unused holes on the fender panel. Actually, the one on the passenger side is used to hold a hose clip in place. Here's what you do:
PASSENGER'S SIDE:
Undo the clip, but do not pull the wire hose out. Leave it where it is, and just stick the ballast over it. It will hold nice and firmly, like in this pic:
Write-Up: HID Conversion - Page 3 100_5790
Dad and I decided to turn the bolt the other way around, so it doesn't look half-assed:
Write-Up: HID Conversion - Page 3 100_5795
And that's just about it. Be careful not to drop the washer or nut, as it's a very tight space to hold everything in.
DRIVER'S SIDE:
For this, the hole is already empty. What we did is put the ballast under the fender panel top, tucked away nice and neatly. You will need a bracket for this. We modified a small 90* bracket to fit the bolts and cut one part off to fit in with the hole on the fender. Just bolt this one on and you're good to go:
Write-Up: HID Conversion - Page 3 100_5792
Write-Up: HID Conversion - Page 3 100_5794
And that's that.
I hope this helps anyone in the future considering to do a HID conversion. It can get tricky and tight, and you will definitely get dirty, but in my opinion, it's all worth it in the end. You get a truly unique appearance, and with 6000K bulbs your visibility is greatly improved. Also, since the car is so low, you don't cause any serious glare or light diffusion towards other drivers.
Feel free to ask me any questions you may have.
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyMon Apr 07, 2008 9:20 pm
i told you that u would like the 6000K
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyMon Apr 07, 2008 9:25 pm
The flicker is gone now, but here is what they look like in the end. Avoid switching from brights to regulars rapidly, where the regulars turn off. Flashing your brights is okay, but the sudden great draws of energy will weaken your ballasts. That's why the Riv bonges at me when I go back into the car.
By the way, if your Riviera has the Light Adriatic Blue Metallic paint, the 6000K HID lights match perfectly!
Merit : 138
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyMon Apr 07, 2008 9:26 pm
I've used 3000, 5000, 8000, 10000, 12000, and 30000 on a few cars and none of them have disappointed. You really can't go wrong.
So now we got at least two members finally putting Mark VIII LSC lights to shame cheers
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyMon Apr 07, 2008 9:44 pm
I hope you don't mean the big neon brakelight! That thing looks nice, and it's why I like the new MKX, or MKZ, or whatever. The Lincoln version of the Ford EDGE.
Gimme that beer! beer
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyWed Apr 09, 2008 11:34 pm
Alright, today I encountered my first problem. As my mom drove down with the lights on to pick me up from driver's ed, I saw that my passenger side lamp was out. I checked the wiring, and everything was fine. Fuses; fine. I called up the guys who sold it to me, not the manufacturer, and told them what was wrong. They looked in the records, saw that I only had it for a week, and helped me do some troubleshooting.
They told me to switch the bulbs to the other side. If the one that was out stayed out and the one that was working stayed on, it's a problem with the bulb, but if the one that was out came on and the one that was on went out, it's a problem with the ballast. Turned out it was the ballast on the passenger side that was faulty. I checked this by putting the factory halogen light straight into the harness, and that worked just fine, so I called them back and they helped me out.
They're sending a replacement ballast FOR FREE. I AM RECOMMENDING THIS GUY TO ANYONE WHO WANTS TO BUY HID KITS ONLINE!!! If you see a seller named "myfavoritesite" then absolutely buy from them! They have the lowest prices, lowest shipping(standard), and some of the best customer service I've seen online!
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyThu Apr 10, 2008 12:07 am
Great write up! How long would you say it took you total?
I plan on doing this eventually.
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyThu Apr 10, 2008 6:12 am
Thanks Anthony! Installation, between testing, installing, and mounting everything it will take you maybe an hour or so. Probably less if you have an idea of what to do, which you will thanks to this, but do be careful. This isn't something you rush, because if you break the bulb trying to mash it in, that's all your fault.
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyThu Apr 10, 2008 9:36 am
what if ii have HUGE hands.......... its hard not breakin stuff neutral
Natesriv
Natesriv
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptySat Apr 12, 2008 10:02 am
Do we have pics of final install & lights on??
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptySat Apr 12, 2008 10:27 am
Look harder. It's on the 1st page.
'96reese
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyTue Apr 29, 2008 1:32 am
did you have to modify the hid bulb itself to get it to fit int he stock location?
'96reese
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyTue Apr 29, 2008 1:38 am
o and do you have to turn your lights on and off manually or do you still use the automatic switch?
PostSubject: Re: Write-Up: HID Conversion   Write-Up: HID Conversion - Page 3 EmptyTue Apr 29, 2008 6:13 am
No bulb modification, and I'd be careful about the auto switch. The other day it was having problems while on the 20A fuses, but if I run the 10A fuses everything works just fine and normal. You can if you want, but they take more power away from the engine's starter motor, so keep them off until the engine's running, especially on a 12 year old car which may have some trouble turning over. I keep the 20's in my glovebox just in case.
'96reese
PostSubject: hid question????   Write-Up: HID Conversion - Page 3 EmptyFri May 02, 2008 10:07 pm
what brands to you guys recommend to buy and what brands to stay away from?
links would be very helpful
Page 2 of 21Go to page : Previous  1, 2, 3 ... 11 ... 21  Next
» Hot Water Heater Conversion kits
» Possible Awning Conversion
» Match target crossbow project
» Crossbow Cannibal - What is this all about?
» Mini Greenhouse Cattle Panels
