 Testing Fuel Pressure, Spark (Chasing KR)
11 posters
Testing Fuel Pressure, Spark (Chasing KR) Empty
PostSubject: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 10:42 am
I am looking for a fuel pressure meter to test fuel rail pressure at WOT. This means I need a gauge that I can install on my schrader valve that will remember max pressure during a WOT run. Does anyone know if the following product will accomplish this?
LINK
It has a pressure release valve, but not sure what is its purpose with the clear tubing on there.... puzzled
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 12:26 pm
when all the pressure builds up and "HOLDS there" what you need to do is "relieve the pressure" which is what the clear tube is for..... its kinda cool i did it on a camaro in class before
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 12:59 pm
Okay, thanks. So it will hold the pressure until I can stop the car, get out and read it after a WOT run. Hope this thing doesn't leak!
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 1:30 pm
That guage will not remember maximum pressure. Their is no check valve between it and the fuel rail. To say that you truely get maximum pressure at WOT is an assumption I'm not 100% sure about. You would pretty much have to hold the gauge outside the engine compartment and read it while you drive. The purge valve/hose is only to make disconnecting safer.
I've have pretty much the same thing and I've hooked it up to the riv - No leaks. Just be careful not to bump the purge valve with it connected.
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 1:40 pm
I was told by INTENSE to measure fuel pressure at WOT. They have some sort of gauge that can do this, but I don't know what they use.
There's no way I'm going to route this thing outside the engine bay while driving. Using a hose that long might throw off the accuracy, imo.
Can't believe there are no fuel pressure gauges out there that can remember a peak reading. I could just install a check valve between the guage and the hose, right?
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 2:33 pm
When I tested mine, I ran a hose long enough to reach my windshield (approx 3') and ziptied the guage to the wipers so I could read it from inside the car while driving. Temporary only!! Accuracy does not diminish through with a longer tube. Good luck not spraying fuel- it always scared me when mine puked fuel on my hot headers when I connected/disconnected.
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 3:14 pm
the only thing I could recommend is the setup I have. (although doesnt bill have one of these gauges on his new SS fuel lines?)
https://2img.net/h/i20.photobucket.com/albums/b246/billboost37/Fuel%20Pump/IMG_3035.jpg
Setup is just an electric fuel pressure gauge mounted in the cab. I used a SS fuel hose from the schrader valve to the fuel sender in the engine bay.
It doesnt have a memory (im pretty sure more expensive electric fuel PSI do though) but I can easily glance a view of my fuel psi at WOT. Its usually about 60 BTW.
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 3:48 pm
You should disconnect the vacuum line when setting your fuel pressure regulator. For WOT testing you need a sending unit type gauge or something that Tees into the fuel line. I suppose if the hose were long enough the thing you showed would be okay - we used a similar setup with the gauge taped to our windshield to eventually figure out we needed more fuel pump for my bro's 455. A different animal I know but we were having lean issues up top and actually ended up installing a second fuel pump triggered by a gas pedal switch... !!
Anyway, how long is the hose on that thing? Find something similar with a longer hose, or get an electric sending unit.
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 4:01 pm
The longer hose version is for older cars, and only goes up to 30 PSI. The unit I have is designed to connect the schrader valve on the front rail. Guess I need an extension hose?
Looking at fuel check valves. Cheapest I can find is $65!
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 4:07 pm
Yeah you don't want a check valve for that anyway. You're not interested in the highest FP, you are interested in watching it at WOT. You want to see if it stays high or not.
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 4:19 pm
Anyone know where I can find a 4-6' long fuel-safe hose to thread onto my schrader valve and feed the pressure meter? I like the idea of taping it to the windshield.
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 4:23 pm
parts stores have fuel hose, usually in 25' rolls though
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyThu Jun 19, 2008 7:36 pm
I had one of those that I bought for my GN years ago. It was pre made with the fitting on one end and a FP gauge on the other.
I think I got it from Cottons Performance.
Bert
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyFri Jun 20, 2008 2:33 am
route it under the car through the trunk up the rear deck over the seat and to the passenger seat..... pretty easy IMO
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyFri Jun 20, 2008 8:26 am
I would like to remove it when I'm finished. rolleyes
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyFri Jun 20, 2008 12:27 pm
http://www.egauges.com/vdo_indA.asp?PN=ATM-3227
maybe?
its what I used. I had to call them to verify that one end does in fact fit onto a schrader valve. The other one goes to a sender unit or straight to the gauge (which would need to be mounted outside the cab for safety reasons)
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyFri Jun 20, 2008 2:02 pm
Thanks, I picked up the JEGS version (exactly the same except 4 ft long), for $35 + tax.
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyMon Jun 23, 2008 12:40 am
Installed the "pillar" fuel gauge today:
Testing Fuel Pressure, Spark (Chasing KR) FuelGAGE1
Testing Fuel Pressure, Spark (Chasing KR) FuelGAGE2
Above is after sitting with engine off, so apparently no leaking injectors. Here's 44 PSI at idle:
Testing Fuel Pressure, Spark (Chasing KR) FuelPSI_1
50 PSI at mild throttle:
Testing Fuel Pressure, Spark (Chasing KR) FuelPSI_2
and 68 PSI at WOT, top of 1st gear:
Testing Fuel Pressure, Spark (Chasing KR) FuelPSI_3
Seems the fuel pump & filter are good!
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyMon Jun 23, 2008 12:43 am
Be honest , you just posted this to show mac features off?
Lol .That looks funny as crap , but its good to know everything is in working order.
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyMon Jun 23, 2008 12:48 am
Well, I don't have any video capture software here, so I just used apple+shift+4 to drag a box around the paused QT window. Easy to upload JPEGs to Photobucket in about 2 minutes, no need to YouTube it. Saved me the hour it takes to edit a movie and upload on dial-up. Can't do that on a PC!
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyMon Jun 23, 2008 12:51 am
lol I knew it! That is pretty cool though.
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyMon Jun 23, 2008 7:15 am
lol
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyMon Jun 23, 2008 12:41 pm
i like that custom install!
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyMon Jun 23, 2008 1:32 pm
It made car feel like something out of Mad Max. I don't know how else I could have done it!
PostSubject: Re: Testing Fuel Pressure, Spark (Chasing KR)   Testing Fuel Pressure, Spark (Chasing KR) EmptyMon Jun 23, 2008 9:45 pm
It's good to know the system is in good shape, though, isn't it?
» 96 Riv has fuel pressure and spark but WONT START
» FAQ: New Riviera Buyer Questions
» Fuel pressure and fuel pump
» To much fuel pressure
» fuel pressure?
