 Back End Boogie
3 posters
Back End Boogie Empty
PostSubject: Back End Boogie   Back End Boogie EmptyMon Jun 30, 2008 8:17 am
Every time I go over a decent sized bump my back end shifts like a broken strut tower.
I have had the car aligned and a new set of air shocks and this still did not cure the problem. They got the back into spec with the alignment but said I still need camber adjustments. My back wheels also look like they're toed in.
Anyone else have this problem?
baynes72
PostSubject: Re: Back End Boogie   Back End Boogie EmptyMon Jun 30, 2008 1:05 pm
had this once before with a lincoln continintal the rear bars were bent.(the ones with the tie rod ends on them) also had this on the riv. was the rear shocks. easy swap 30 min. per side and 70.00 at autozone
PostSubject: Re: Back End Boogie   Back End Boogie EmptyMon Jun 30, 2008 4:40 pm
Is the back end up really high? Like a stuck/broken air pump? Does your air pump run all the time? Sounds like the air shocks are jacked up...
There are also upper rear control arm bushings and such. The rear suspension has a lot to it, but a good tech should be able to find the problem. It's just a G-body, there are a million of em out there.
Try unhooking the air line and letting the shocks air all the way down.
PostSubject: Re: Back End Boogie   Back End Boogie EmptyTue Jul 01, 2008 7:21 am
I bypassed the compressor and put a valve underneath the bumper. I keep them about halfway. I have tried letting all the air out and no luck.
I have had the car aligned 3 times at goodyear because my back tires kept scalloping on the edges.
They replaced my tires 3 times and now they want to do it again. I told them to screw off because they are ruining my rims by taking tires on and off so much.
I am tired of them.
Back End Boogie
» I'm back!!!!!
» I'm Back
» Got the green riv back
» Eric's calling you out alex...heheh
» Got My Riv BACK!!!!!
