BillBoost37 Junkie
| Subject: I'm sorry Mon Jul 07, 2008 1:16 pm | |
| I know our cars share a torque axis mount and I've kinda hinted that a couple of you should realize it's not that hard to change a belt and just man up to the job.
Well this weekend I had the pleasure of learning something about the Riviera TA mount. The bottom bolt that comes out in order to put the belt in hits the freaking body! In the Bonnie it clears and it's not that hard of a job. You guys have a slightly different body side mount and we had to lower the motor a little in order to slide out the stud.
The upside is ..now I know all you guys need to do is remove the main TA bolt first, then lower the motor slightly and remove that stud. Sorry to say... it's only 1 more step. (Stil sucks though) | |
| Subject: Re: I'm sorry Mon Jul 07, 2008 4:42 pm | |
| Seems there's always something to make working on the Rivs a bit more complicated. For the infrequent occassion that I'll need to change belts, I'll also make a point of changing the lower SC idler pulley while I'm in there. Which means I HAVE to remove that entire mount, to get at that pulley. Of course in the event of a mishap resulting in premature belt failure, I'll certainly take the "belt-only" shortcut, it's a no-brainer. | |
| Subject: Re: I'm sorry Mon Jul 07, 2008 5:13 pm | |
| It's _only_ one more step, but it's the step that requires some kind of hoist. First time I did one I was mid-job and used a board and floor jack. Ended up doing the oil pan gasket 3 months later. Don't do that!! | |
| Subject: Re: I'm sorry Tue Jul 08, 2008 12:02 am | |
| i always use a 2x4 and jack to support it. never had a problem. last time it took me just over an hour to do the belts on a riv, i've even done them in a parking lot, with the stock tire jack (upside down to support the engine), and always just hand tools. belts dont scare me anymore on these cars _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
BillBoost37 Junkie
| Subject: Re: I'm sorry Tue Jul 08, 2008 7:28 am | |
| Odd that you mention the pan gasket. The Bonnie shares the same plastic crappy gasket (from the factory) and the FSM says to just the jack and board method on the pan.
In Oldsman's case, he has switched over to the 00+ Bonne structural aluminum pan. Yes structural, they use it for two of the three bolts for the motor mount.. Jacking is not a concern with his pan.
Overall though..I simply didn't realize they could make that bracket any worse to deal with....lol | |
