| What to do next? | |
+41998 Riv AA TonySmooth89 oldsman105 8 posters |
What to do next? | Exhaust | | 73% | [ 8 ] | Bigger throttle body | | 27% | [ 3 ] | Other | | 0% | [ 0 ] |
| Total Votes : 11 | | |
oldsman105 Junkie
| Subject: What to do next? Sun Jul 13, 2008 4:23 pm | |
| Well now that the transmission has been repaired and working well, I really want to take the Riviera to the track. But before I do I am considering doing one more Mod to the Riviera. Either a Bigger TB ( Ported stock, N*, LS1 ). Or I might do the exhaust. 3" pipe 3" resonator to a single Hi-flow muffler with 2 2.5 outs.
I figure both will help my trap a hair. And my car seems to fall on its face above 80 MPH.
Which of the two would you choose? Or if you have suggestion "except a Cam" please make it.
Thanks in advance
Last edited by oldsman105 on Sun Jul 13, 2008 8:51 pm; edited 1 time in total (Reason for editing : added poll) | |
TonySmooth89 Aficionado
| Subject: Re: What to do next? Sun Jul 13, 2008 8:11 pm | |
| I plan on doing the ported throttle body soon enough. I think theres a guy on regalgs.org who gained 2mph on the traps. I don't think thats normal , but hes now trapping like 102-103 without headers or rockers. | |
| Subject: Re: What to do next? Sun Jul 13, 2008 10:13 pm | |
| I like the exhaust upgrade idea. Bigger pipes might let you run the 3.3" pulley, but a bigger TB surely won't. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: What to do next? Sun Jul 13, 2008 10:27 pm | |
| I suppose it doesn;t help to mention that intense has their cams 10% off until the 15th...
I know i know... you said not a cam...
But its a good deal. | |
| Subject: Re: What to do next? Mon Jul 14, 2008 12:07 am | |
| I voted for exhaust, but really think a cam should be in the mix. I'm surprised at the "falling on its face above 80" comment. Figured the rockers would be doing the job up there. | |
oldsman105 Junkie
| Subject: Re: What to do next? Mon Jul 14, 2008 9:50 am | |
| - 1998 Riv wrote:
- I voted for exhaust, but really think a cam should be in the mix. I'm surprised at the "falling on its face above 80" comment. Figured the rockers would be doing the job up there.
I figured the rockers would help but I don't see it. I figure my car is hungry or constipated | |
| Subject: Re: What to do next? Mon Jul 14, 2008 9:58 am | |
| My rockers seem to run out of steam around 5800 RPM. I think it's normal. But I'm well above 80 mph at that point. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
rivwilly107 Enthusiast
Name : Jim Age : 52 Location : Groton NY Joined : 2008-06-23 Post Count : 232 Merit : 0
| Subject: Re: What to do next? Mon Jul 14, 2008 11:16 am | |
- My rockers seem to run out of steam around 5800 RPM. I think it's normal. But I'm well above 80 mph at that point.
What are your shiftpoints? | |
| Subject: Re: What to do next? Mon Jul 14, 2008 12:43 pm | |
| My WOT shift points are 5700 RPM from 1-2, and 5700 RPM again from 2-3. I've experimented with higher shift points, but for my car, these points provide close to optimum power delivery while being fairly safe to the engine and trans. I could squeeze a little more power out of the car, but not enough to justify putting such stress on the drivetrain. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
oldsman105 Junkie
| Subject: Re: What to do next? Mon Jul 14, 2008 6:39 pm | |
| Well it looks like I am going for exhaust. | |
| Subject: Re: What to do next? Mon Jul 14, 2008 6:57 pm | |
| In my opinion, especially with those injectors and a tuner, you should be able to run a 3.2" pulley no problem, maybe pick up the LQ4 maf sensor (w/ or w/o bigger TB) to make tuning a little more certain, and that pulley with some adjustment aught to give you a nice boost you're looking for, no pun intended. | |
oldsman105 Junkie
| Subject: Re: What to do next? Mon Jul 14, 2008 7:59 pm | |
| Tuning for anything smaller then the 3.4 has been Hell. I am really starting to think my exhaust is holding me back. | |
palermocorey90 Expert
Name : Corey Age : 34 Location : Rome NY Joined : 2007-10-03 Post Count : 2968 Merit : -24
| Subject: Re: What to do next? Mon Jul 14, 2008 8:14 pm | |
CAM FTW but i would do exhaust 2.5" mandrel bent | |
| Subject: Re: What to do next? Mon Jul 14, 2008 9:38 pm | |
| You and I are pretty much in the same boat with mods. I have a helluva time getting my 3.2 to run consistently, the 3.4 pulls as well as the 3.2. Exhaust is next on my list. | |
| Subject: Re: What to do next? Mon Jul 14, 2008 9:48 pm | |
| - deekster_caddy wrote:
- You and I are pretty much in the same boat with mods. I have a helluva time getting my 3.2 to run consistently, the 3.4 pulls as well as the 3.2. Exhaust is next on my list.
im sorry i found that funny as hell Boat was just funny as hell. | |
| Subject: Re: What to do next? Tue Jul 15, 2008 10:05 am | |
| I don't have a tuner but I can tell you my riv pulls quite noticably harder with the 3.2" than it does with the 3.4" and I don't even have the mods or tuning capability yall do.
I know because when it started getting hot out and I didn't have the cam in yet, I put the 3.4" back on and it felt like dog slow to me in comparison. | |
| Subject: Re: What to do next? Tue Jul 15, 2008 10:15 am | |
| My 3.2" also pulls noticeably harder, because it makes more torque down low, but it doesn't make my car that much faster, because that torque doesn't equate to much extra HP, if any. Ran 13.9 secs ET with 3.2", ran 14.0 with 3.4".
If I had a cam or IC, I might be able to get more out of the 3.2", but with my current set-up, the extra boost wasn't doing me much good. But does feel faster with everyday driving. Throttle response is very nice. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: What to do next? | |
