| Supercharger pulley bolt? | |
+4Chicken 1998 Riv TonySmooth89 1wickedninja 8 posters |
1wickedninja Addict
Name : Josh Age : 36 Location : port saint lucie, Fl Joined : 2008-07-30 Post Count : 647 Merit : 5
| Subject: Supercharger pulley bolt? Mon Aug 18, 2008 4:33 pm | |
| can someone please help me out and tell me were I can find the bolt that goes on the end of the supercharger pulley? It broke on me I allready tried the dealer they told me they only sell it with the supercharged in a kit. | |
TonySmooth89 Aficionado
| Subject: Re: Supercharger pulley bolt? Mon Aug 18, 2008 4:36 pm | |
| http://www.zzperformance.com/grand_prix/products1.php?id=594&catid=106
i think thats what you want. | |
| Subject: Re: Supercharger pulley bolt? Mon Aug 18, 2008 4:39 pm | |
| Yep, that's it. You could also go to a local salvage yard and pull one. ZZP's is used also. | |
1wickedninja Addict
| Subject: Re: Supercharger pulley bolt? Mon Aug 18, 2008 4:40 pm | |
| thanks man that's a big help dam dealer don't even sell them seprate. | |
Chicken Aficionado
| Subject: Re: Supercharger pulley bolt? Mon Aug 18, 2008 4:42 pm | |
| Are those breathers even needed? | |
1wickedninja Addict
| Subject: Re: Supercharger pulley bolt? Mon Aug 18, 2008 4:49 pm | |
| Is it safe to run the car without it untill it gets here? | |
1wickedninja Addict
| Subject: Re: Supercharger pulley bolt? Mon Aug 18, 2008 5:34 pm | |
| I just put a bolt with a washer with the same treads and about the same lengh for now the vent bolt should be here like thursday with the pulley pulled and instaler. | |
Supercharged Addict
Name : Blake Age : 34 Location : Akron, Ohio Joined : 2008-03-12 Post Count : 611 Merit : 0
| Subject: Re: Supercharger pulley bolt? Mon Aug 18, 2008 6:00 pm | |
| my best guess would say no | |
Chicken Aficionado
| Subject: Re: Supercharger pulley bolt? Mon Aug 18, 2008 6:04 pm | |
| ..and can you specify why?
the reason I'm asking is because when I dropped pulley sizes the m12? stud for the pulley puller broke off in my shaft and I still haven't removed it.... | |
1wickedninja Addict
| Subject: Re: Supercharger pulley bolt? Mon Aug 18, 2008 9:06 pm | |
| I'm wondering to chicken? | |
| Subject: Re: Supercharger pulley bolt? Mon Aug 18, 2008 9:11 pm | |
| - Chicken wrote:
- ...stud for the pulley puller broke off in my shaft and I still haven't removed it....
Ouch... you should get that looked at! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Chicken Aficionado
| Subject: Re: Supercharger pulley bolt? Tue Aug 19, 2008 9:21 am | |
| Subject: Re: Supercharger pulley bolt? Thu Aug 21, 2008 9:42 pm | |
| Some people put one of those plastic push-plugs in the end of the shaft. For a while they came with MPS kits. It should not be wide open, and it should not have a bolt. The factory thing is a breather. It needs to be vented or you'll leak oil from an inner seal. The broken piece of a pulley puller stud is probably enough to prevent dirt from getting in there, and should not seal tight enough to blow a seal, so you should be alright. | |
Chicken Aficionado
| Subject: Re: Supercharger pulley bolt? Fri Aug 22, 2008 9:23 am | |
| So should I add it to my signature as a mod? | |
dscott2000 Enthusiast
Name : Scott Age : 42 Location : Kansas City, MO Joined : 2008-07-27 Post Count : 160 Merit : 0
| Subject: Re: Supercharger pulley bolt? Sun Aug 31, 2008 9:30 pm | |
| - 1wickedninja wrote:
- Is it safe to run the car without it untill it gets here?
My nephew bought a GTP without the blower belt. he drove it for about a week without it. I noticed it not having a belt and put one on for him. The supercharger ended up being ok. The 3800 S/C engine runs just like a regular 3800 without it. So, to answer your question, Yes, it can be ran without the S/C for a limited time until your part gets there. Even though it is frowned upon. | |
| Subject: Re: Supercharger pulley bolt? | |
