Just found this on ALLDATA....REV-ON!!!
1998 Buick Riviera V6-3.8L SC VIN 1
Vehicle Level Transmission and Drivetrain Automatic Transmission/Transaxle Fluid - A/T Technical Service Bulletins A/T - DEXRON(R) VI Fluid Availability
Notes
Bulletin No.: 04-07-30-037B
Date: June 12, 2006
INFORMATION
Subject:
Release of DEXRON(R) VI Automatic Transmission Fluid (ATF)
Models:
2007 and Prior Passenger Cars and Light Duty Trucks
2003-2007 HUMMER H2
2006-2007 HUMMER H3
2005-2007 Saturn Relay
2005 and Prior Saturn L-Series
2005-2007 Saturn ION
2005-2007 Saturn VUE with 4T45-E
2005-2007 Saab 9-7X
Except 2007 and Prior Chevrolet Aveo, Epica, Equinox, Optra
Except 2007 and Prior Pontiac Torrent, Vibe, Wave
Except 2003-2005 Saturn ION with CVT or AF23 Only
Except 1991-2002 Saturn S-Series
Except 2007 and Prior Saturn VUE with CVT, AF33 or 5AT (MJ7/MJ8) Transmission Only
Supercede:
This bulletin is being updated with the 2007 model year. Please discard Corporate Bulletin Number 04-07-30-037A (Section 07 - Transmission/Transaxle).
DEXRON(R)-VI ATF
General Motors Powertrain has recently upgraded to DEXRON(R)-VI ATF with the start of 2006 vehicle production.
Only 2005 and prior models that currently use DEXRON(R)-III may use DEXRON(R)-VI as a replacement.
All 2006 and future models that use DEXRON(R)-VI are to be serviced with DEXRON(R)-VI fluid only.
DEXRON(R)-VI is an improvement over DEXRON(R)-III in the areas shown.
2006-2007 Transmission Fill and Cooler Flushing
Some new applications of the 6L80 six speed transmission will require the use of J 45096 - Flushing and Flow Tester to accomplish transmission fluid fill. It is highly recommended that the clean oil reserve of the machine be purged of DEXRON(R)-III and filled with DEXRON(R)-VI.
Parts Information
Disclaimer
© 2008 ALLDATA LLC. All rights reserved.
Terms of Use
