lyonsperformance Enthusiast
Name : Michael Age : 40 Location : Buffalo N.Y. Joined : 2008-08-02 Post Count : 178 Merit : 0
| Subject: unknown "problem" Sun Sep 07, 2008 7:10 pm | |
| I notice the other day that when im cruising down the thruway, when i give the Riv some gas to pass or get around someone, it seems as thought it drops in rpm slightly before it picks up speed, anyone have this happen to them? | |
| Subject: Re: unknown "problem" Sun Sep 07, 2008 7:31 pm | |
| It's normal for the engine to do this if you are in OD at freeway speeds. When the TCC locks-up, the added load bogs the engine a little bit. This can be remedied with a PCM tuner. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: unknown "problem" Sun Sep 07, 2008 7:33 pm | |
| Yeah i really gotta get myself in gear and get tuned up soon. thanks | |
| Subject: Re: unknown "problem" Sun Sep 07, 2008 9:29 pm | |
| See if it makes any difference how quickly you stab at the gas pedal. With a gradual push, it will first try harder to keep the TCC locked, which whill result in a slight RPM drop. If you nail it it should just unlock and upshift right away. | |
| Subject: Re: unknown "problem" Sun Sep 07, 2008 9:35 pm | |
| yeah thats exactly what i do, and those are the exact results i get from changes in pedal pressure. guess ill just have to deal with it. | |
| Subject: Re: unknown "problem" | |
