 FAQ: Power Steering Pump & Hoses - Noise & Problems
ecotecjosh
joshuatim
rocafella1
jamie
R1V13RA
tech408
Mikel
jordynarz
98RIV7777
manofmany
SupersportSteve
27 posters
FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 Empty
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyWed Jul 01, 2009 4:21 pm
Well, It's very difficult to diagnose noises from the front of the engine because there are so many possibilities with all the pulley bearings and such being driven by the belts.
It's even more difficult to diagnose noises on the internet, sorry.
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyWed Jul 01, 2009 4:36 pm
i think its the pump.
a pump shouldnt be expensive...there were a lot of series ones out there.
jordynarz
jordynarz
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyWed Jul 01, 2009 5:29 pm
Also I wish I could replace my coil packs because my motor misses and doesnt fire properly under acceleration.
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyWed Jul 01, 2009 5:46 pm
Most likely not your coil packs. Missing under acceleration is usually just wires and plug issue.
Very rarely do the coil packs go bad and when they do it will affect firing under all rpm's most of the time.
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyThu Jul 02, 2009 9:47 am
You may want to remove the coils and the Ignition Control Module that they are mounted on. It's just a flat plate. Clean the bottom and top of any corrosion that has built up under there and check - clean the ground connection which is also right there attached to the module.
Apply a light film of Dielectric Grease to the bottom surface of the ICM and reassemble.
Even if this is not part of your problem it is good preventive maintenance.
Mikel
PostSubject: Power steering trouble   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyMon Aug 17, 2009 11:42 pm
Hello,
Today, I was doing a three point U-turn in my '97 and as I was turning the wheel, the power steering died like a switch had just been flipped. The belt is good, there is fluid in the pump and nothing is dripping. There is a little belt squealing from time to time. Steering is OK, but very, very heavy. Prior to this, the steering worked flawlessly.
I'm crossing my fingers hoping it's just the pump that needs to be replaced, but I have never seen a pump fail so suddenly. They usually die a long predictable death.
Any ideas? Thank you.
Mikel
tech408
tech408
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 12:18 am
It sounds like the speed sensitive steering has been activated to highway mode. This could happen for many reasons. The best place to start is see if there are any fault codes not only in the ECM but also the ABS. The car might think it's at highway speeds because of an erroneous signal from one of the sensors.
Merit : 104
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 12:27 am
Hi Mikel,
I have a '97, and while it technically wasn't as sudden as yours, I thought I'd tell you my story...
Through THREE steering pumps I've had at least one "groan per cycle" in the steering system. I think that when you shut down, the system sucks a vacuum that it wouldn't have in the days of plain, vented caps on the steering pump...
More to the point, the first time that I changed the pump, it was worse than the original, making more noise and providing less boost... I had to replace that "brand new" pump in 2 weeks time.
I don't think your problem could be electronic, simply because the worst the system can get if the MagnaSteer fails is "regular" hi-speed boost...
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 6:13 am
Eldo,
I know is seems contrary to the way Magna-Steer works but, if you disconnect the two wire plug on top of the steering rack that feeds the Magna-Steer, on a perfectly good system, It defaults to unassisted steering.
The steering will be more difficult at idle and low speeds all the way up to highway speed.
I don't know why this is but it is. I disconnected mine for a couple of weeks to diagnose another problem and was shocked to feel the steering effort had increased throughout all RPM's and Speeds.
Logic says the steering effort should decrease but it didn't.
Just my $0.02.
Mikel
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 6:14 am
Hello,
If it helps, the steering was always VERY soft, at any speed, which I thought was a bit annoying. I just thought it was the way the car had been designed, so I learned to live with it. Even on the highway, now it takes A LOT of effort to steer when making sharper than usual turns.
I don't seem to have any error codes (or at least not check engine light).
Thanks,
Mikel
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 6:27 am
A failure in the Magna-Steer system will not trigger any lights nor store any codes.
It is not a necessary system as far as the computer is concerned and the car will work and drive OK without Magna-Steer.
If you indeed have a failure of the Magna-Steer system you can choose to ignore it and continue driving it the way it is or replace the whole steering rack for a bunch of $$$$.
An interesting side note:
I did some research on trying to find a replacement rack for the Rivieras that doesn't have Magna-Steer to keep the cost of rack replacement down.
What led me to that path was I found out you could get a replacement re-man Bonneville steering rack with or without magnasteer for the same vehicle. That is because the car came from the factory with magnasteer as an option.
Whenever I asked the parts guys about a listing for non - magnasteer on the Riv I was told it doesn't exist, presumably because this car did not offer a non - magnasteer version.
What needs to be done now is to find out what other cars share the same steering rack then order the non - magnasteer for that vehicle.
I personally like the way it felt with the magnasteer disconnected.
Mikel
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 6:55 am
A couple of points:
I just started the car in the morning, and I hear a grinding noise coming from the P/S pump. I suppose a Magna-Steer failure wouldn't cause this...?
The amount of effort required to steer is IMMENSE, as if all power steering had been lost. It takes all my might (which is not much) to make tight turns when the car is rolling..
Thanks,
Mikel
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 7:07 am
Well. with that amount of steering effort I would be more inclined to say you have a pump failure issue.
I would change the pump and try to drain or flush as much of the old fluid from the steering rack while you have the old pump out and before putting in the new pump. Try disconnecting the lines at the rack while the car is jacked up and rotating the steering wheel with engine off and see how much fluid you can get out of the rack.
Anyone else have any ideas of how to flush the rack in the driveway.?
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 10:03 am
re flushing the rack in the driveway - I'd do what Rick said EXCEPT I would buy TWO Cardone power steering filters. I would install one when I put the new pump on. Follow the instructions that come with it, if you have the option to do so. THen after a week or so I would replace that filter.
As far as the pump is concerned - if you do the job yourself it is not terribly expensive. It's one of the standard Saginaw pumps that is used on a bunch of different GM vehicles. The problem is the cheapest one, however, will not have a pulley installed already and will not have the electronic variableorifice valve installed. But if you know how to install pulley (that is, you have the air tools needed) it's no big deal to move the pulley from the old pump to new, adn I imagine the orifice valve is not that big a deal wither although I have not done that. If not, then please get a pump with the pulley already installed or take it to a mechanic for replacement - a fully dressed new pump will cost you $$$, like $200-plus. Reman pumps that you have to fit with your own reservoir and valve are about half that.
Mikel
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 10:13 am
Thank you - Got a P/N for the Cardone P/S filters?
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 10:15 am
Thanks for the tip on the filters. I forgot about their availability.
I've priced out a complete pump with pulley, pressure valve and New Reservoir installed before. I don't remember them being that much, but my memory isn't that good.
I don't know why they sell reman units without the reservoir as that is one of the components I would want completely clean and preferably new when installing a replacement pump.
Even though I have the capability and equipment to clean the res. I would still opt for the unit that has a new one installed along with all the other things mentioned.
Take a look at www.cardone.com for the filters and pump P/n's
My pump has started to groan a little and I recently looked at the cardone site so I can find a cardone reman locally by P/N. And will be ordering a filter as well.
Mikel
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 3:05 pm
It was the pump. The mainshaft is held in place by a clip that had broken and allowed the shaft to slip out of the splined area in the pump. It's working now! I'll get an inline filter, just in case.
Thank you all.
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 3:35 pm
RickW:
Rick I have been thinging about disconnecting mine as well but thought the ABS/TC light would stay on. Why did you re-connect it if you liked the way it felt disabled?
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 3:43 pm
the pumps and filters seem to be fairly priced on rockauto.com...
and as for the reservoir, they clean up fine using dry gas (the cheapest kind, whcih is straight isopropyl or methyl alcohol). use a brush if thre is residue in the corners. If you have time to wait for air drying, then use Dawn dish liquid and wter to do the cleaning.
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 3:57 pm
ewolfe0050 wrote:
RickW:
Well I did re-connect it for a while then dis-connected again. I tie wrapped bags over the electrical connectors to keep them from getting too corroded.
I will keep it disconnected for now. Once I put a larger diameter wheels and wider tires on it I'll see how the steering effort is then. If it takes too much effort due to the tires I may reconnect.
If your going to try it, let me know about the steering effort.
Disconnecting it will have no effect on ABS/TCS or any other system.
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 4:00 pm
Thanks Albert,
I'll look at Rock Auto. Was planning on making a fairly large order from them for GF's vehicle. Have to be careful with them about everything coming from the same warehouse or you get hosed on shipping cost's.
Have already figured out her order now I'll either add to that order or start a new one for me.
Mikel
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 4:16 pm
By the way, old pump had no special valving or wires going into it anywhere. Did all 97's have the Magna Steer?
Is the valving in the rack/pinion assembly?
http://delphi.com/manufacturers/auto/other/steering/gears/magna/
FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 Str_magnasteer_drwg_th
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 4:18 pm
All the Riviera's 95-99 had Magna-Steer as standard equipment.
Yes, All the Magna-Steer components are built into the steering rack. That's what makes them so expensive to replace compared to a non Magna-Steer rack.
Merit : 104
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 4:20 pm
Eldo,
Just my $0.02.
No, not contrary at all, Rick. I think we're just saying the same thing with different words. When I said "regular hi-speed boost", I meant the lower-power, highway-mode setting. I think that's what you're getting when you refer to "unassisted steering"...
Truly unassisted steering is what Mikel had, and it did indeed turn out to be the pump.
Mikel
PostSubject: Re: FAQ: Power Steering Pump & Hoses - Noise & Problems   FAQ: Power Steering Pump & Hoses - Noise & Problems - Page 2 EmptyTue Aug 18, 2009 4:22 pm
I was curious, because my steering is way too soft even at high speeds. Maybe it's that I'm one of them yurropeens and I expect cars to feel a little differently, as much as I love my Riviera tongue
If anyone is looking for a cheap steering assembly, try www.car-part.com My local yard has 4 Rivieras.
» Power steering thumping noise
» power steering pump?
» Power steering problems
» Steering shudder, pump or rack noise?
» FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting
