| K@N air | |
willie98 Special
| Subject: K@N air Wed Mar 04, 2009 7:23 pm | |
| I own a 98 riviera, and wanted to replace the stock air filter with a drop in K@N air filter. But my father who is a auto mechanic says that the oil from the K@N air filter might damage the mass air flow sensor. Is this true? | |
Buapo Addict
Name : Ben Age : 39 Location : Eastlake, OH Joined : 2007-07-17 Post Count : 691 Merit : 2
| Subject: Re: K@N air Wed Mar 04, 2009 7:27 pm | |
| I had no problems running a K&N drop in filter for 5,000 miles. I haven't seen anyone report anything on here about the K&N filter.
I'm currently using a 9" K&N cone which is oiled, of course, for the past 10k miles and no problems yet.
I wouldn't feel uncomfortable recommending it, but figure out where you want your car to be in the future as far as power goes. Because a gutted box with a K&N is more restrictive than a fenderwell intake (FWI) or a cold air intake.
In other words, don't waste your money on a $70 filter if you're just going to replace it later. I ended up selling my filter on here for half what I paid, because I was eager to start modding. | |
| Subject: Re: K@N air Wed Mar 04, 2009 7:31 pm | |
| He is sorta correct. It could do exactly as he says. Probably the worst thing that would happen is it would dirty the MAF sensor and cause some rough idling or odd acceleration behavior.
However, I've been running a K&N filter for years with no trouble. The key is not to over oil the filter. If you do as the instructions say, and refresh the oil in the proper amount, it should not cause any problem. If it does, just remove the MAF sensor and carefully clean it with some electronic parts cleaner.
Good luck! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: K@N air Wed Mar 04, 2009 9:29 pm | |
X2
Don't over-oil the K&N and it will NOT foul up your MAF sensor. You should pull the sensor and clean it once a year or so anyway, with the proper electronics spray cleaner. | |
| Subject: Re: K@N air Wed Mar 04, 2009 9:33 pm | |
| How often do you guys oil the K&N? | |
| Subject: Re: K@N air Wed Mar 04, 2009 9:38 pm | |
| I try to clean it every 6 months. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Buapo Addict
| Subject: Re: K@N air Wed Mar 04, 2009 11:23 pm | |
| 6 months x 2. Doesn't seem to be all that dirty either. | |
| Subject: Re: K@N air Wed Mar 04, 2009 11:36 pm | |
| How many miles do you guys usually hit in 6 months? | |
| Subject: Re: K@N air Wed Mar 04, 2009 11:39 pm | |
| 12-13k for me. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Buapo Addict
| Subject: Re: K@N air Wed Mar 04, 2009 11:43 pm | |
| 5k in 6 months, probably. Maybe less. | |
99prixgt Member
Name : Erik Age : 37 Location : NJ Joined : 2009-01-27 Post Count : 90 Merit : 2
| Subject: Re: K@N air Thu Mar 05, 2009 5:33 am | |
| K&N? . I had put in one of their "high flow" drop in filters and it clogged up my MAF sensor, cost me $$$. Their isn't any benefit with "high flow" drop in filters. Only type of gains you would really see is if you go CAI with the least amount of bends in the pipe for ultimate flow. Look into dryflow filters. | |
curious riv Addict
Name : Chris Age : 44 Location : C'view FL Joined : 2008-10-20 Post Count : 521 Merit : 3
| Subject: Re: K@N air Fri Mar 06, 2009 1:03 pm | |
| im satisfied w my k&n drop in. got it from buapo not too long ago. | |
| Subject: Re: K@N air Fri Mar 06, 2009 8:22 pm | |
| It sure felt like I picked up some power when I put my K&N in. | |
Buapo Addict
| Subject: Re: K@N air Fri Mar 06, 2009 8:52 pm | |
| I noticed an increase in power with a drop in, but I also gutted my box, which I'm sure helped some. Then, I got a simlar performance gain over the K&N drop in when I went to the FWI, with 9" K&N cone filter. | |
| Subject: Re: K@N air | |
| K@N air | |
