ihartmacz Amateur
 | Subject: Two Questions Mon Apr 02, 2007 11:15 pm | |
| 1. My turn signals aren't working. I noticed a while ago that the blinker is really quiet, no it doesn't blink at all, and the out side lights don't blink... They worked before! I'm thinking that its just the fuse. The lights work fine, and the hazard lights flash too on the outside.
2. Whats the best way to relieve fuel system pressure on the 3800? I want to replace my fuel filter. | |
gosloriv Enthusiast
Name : David Age : 49 Location : Elyria,Ohio Joined : 2007-03-15 Post Count : 152 Merit : 0
 | Subject: Re: Two Questions Mon Apr 02, 2007 11:19 pm | |
| U have a bad flasher wich is seperate from the emrgency flasher.If the turn sig lights go on, when actavated. There should be a fuel pressure test port on the fuel rail wich the shrader valve can be pressed to releave pressure. | |
jax95riv Aficionado
Name : Jack Age : 60 Location : Oklahoma City Joined : 2007-01-14 Post Count : 1062 Merit : 6
 | Subject: Re: Two Questions Mon Apr 02, 2007 11:28 pm | |
| The flasher located on the driver side up under the dash sounds like the problem to your first question.
Can't help with your other question...sorry bro | |
Name : Matthew Age : 36 Location : Florida Joined : 2007-01-17 Post Count : 4394 Merit : 101
 | Subject: Re: Two Questions Wed Apr 04, 2007 9:59 am | |
| if you use the pressure test spot on the engine then you will have a engine bay and possibly some paint covered in gas. you can either remove the fuel pump fuse and run the car till its dead, or just do like i do and slowly remove the filter and let the 1/2 gallon drain. no matter what you do there will be some gas still in the line and filter. at least ours is easy to access  _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
 | Subject: Re: Two Questions Wed Apr 04, 2007 10:09 am | |
| Use a rag. It's not that much fuel. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Two Questions  | |
