T Riley Guru
| Subject: Torque Convertor Stall! Mon Nov 02, 2009 2:24 am | |
| Alright.. While I have my motor out.. It would be super easy to swap out to a higher stall TQ convertor.. Stock is in the 2300 range IIRC.. I found one on Clubgp for 250shipped http://www.clubgp.com/newforum/tm.asp?m=5074795&p=2&tmode=1&smode=1
What are your guy's opinions on a higher stall? | |
| Subject: Re: Torque Convertor Stall! Mon Nov 02, 2009 8:29 am | |
| what are your plans for the car? If you do any kind of city driving I would recommend a stock converter. It will hurt gas milage and increase overall wear and tear of the transmission. However, it's will allow the engine to rev a little higher on launch, allowing for better traction control at the dragstrip. If you have a large cam with a much higher powerband, then the appropriate sized converter will get you up to it's powerband quicker. It all depends on your new motor build's specs and intended use.
I stayed with my stock converter. I don't like high RPM converters, I find it makes city driving very annoying. | |
T Riley Guru
| Subject: Re: Torque Convertor Stall! Mon Nov 02, 2009 2:49 pm | |
| - deekster_caddy wrote:
- what are your plans for the car? If you do any kind of city driving I would recommend a stock converter. It will hurt gas milage and increase overall wear and tear of the transmission. However, it's will allow the engine to rev a little higher on launch, allowing for better traction control at the dragstrip. If you have a large cam with a much higher powerband, then the appropriate sized converter will get you up to it's powerband quicker. It all depends on your new motor build's specs and intended use.
I stayed with my stock converter. I don't like high RPM converters, I find it makes city driving very annoying. My plans for this car are to retire it to a Weekend warrior once i move out.. and can afford another car. I guess I'm going to leave the TQ converter alone for now.. It's not really that hard to pull the motor. so someday i'll pull it again and put in a 3k stall.. | |
| Subject: Re: Torque Convertor Stall! | |
