As I said in my writeup, my brother the mechanic was surprised that my pin came out because he's never seen this problem - but he's had to PULL the pins to tighten screws that came loose...
On the other hand, the round tilt-columns in my Pontiac and Cadillac accumulated a total of 450,000 miles without coming apart... Put it this way, not all Cadillac 4100's blew up, but it was still a crappy design.
Name : Rick Location : Lancaster, MA Joined : 2008-09-13Post Count : 6281 Merit : 119
Beyond the beloved Cadilac, Has anybody got an explanation for the Riviera situation.
Regarding your brother mentioning the need to pull the pins to tighten screws, what screws.? From the pictures i saw there are no screws holding the pins in, that's why I suggested adding some. Am I missing something here or did I walk in the middle of a movie.????????????????????
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09Post Count : 3107 Merit : 104
Yes, I think you did come in in the middle... We've talked about the inadequate way these pins were held in at the factory earlier in this thread: friction and a couple of dimples in the surrounding metal.
As I inferred above, not all crappy designs fail, but not everyone uses the tilt-wheel every time they get in the car... My mother had tilt in every car since '73, but never used it til '93. Constant use of the tilt makes these pins likely to come loose.
As for the screws my brother was talking about, they are down inside - thus the need to pull the pins and separate the joint.
For those of you that have a worn coupling with loose pins, I still think my repair scheme is a good one and will last for the remainder of the life of the car, if done properly.
I can draw a Blueprint if necessary, but I think the explanation was clear enough for anybody with some mechanical ability.
I will assume then that I do not have the problem because I do not use the tilt feature (set it and forget it) and possibly the previous and only other owner may not have used it either.
So, if I should Total the car in the near future, and I plus the steering column survive, then there will be one up for sale at a premium price. Just in case you happen to be one of those people that just can't stop jerking the lever on the steering column.
Precisely...
Hey, when you get to my age and infirmity, you'll need every bit of help you can get to climb in & out of these cars!
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13Post Count : 18438 Merit : 248
Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Aug 03, 2010 1:05 am
I don't think it's caused strictly from use of the tilt feature, as I've never used it, except to work under the dash. And one of my pins fell out before 50k miles. I think it has more to do with how aggressive you are with turning the wheel, and luck. Having said that, I've coped with this for such a long time, and have gotten used to it - it's one of those things I'll fix for sure, next time I remove the dash.
Name : Codith Age : 35 Location : Villa Park, IL Joined : 2007-02-08Post Count : 3671 Merit : 140
Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Aug 03, 2010 1:30 am
Rick, someone said early in the thread that these pins are pressed in from the factory. They should never really move or get loose until the softer surfaces they fit into wear. Mine can move now but I don't think they were meant to. In my pictures you can see factory markings of alignment.
With your idea of tapping them, what part are you thinking of threading? the outter part or the inner part? If you thread the inner part then the pin will be moving or twisting with the wrong part of the column and you have virtually no smooth surface for the assembly to tilt on. In other words, the bushing effect that the pin itself provides is gone. If you thread the outter part, you would need to custom machine your own pins with threads near the head that have 2 different diameters for the inside - essentially recreate the same pins that are in there but with a screw head and a very small threaded area.
Sorry, I'm bad at explaining stuff but I tried.
Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Aug 03, 2010 1:50 am
As I said, for most people it would likely require dropping the column, but what Rick is suggesting is drilling & tapping a hole in the ear, right next to the surface of the pin, and putting a pan-head screw into it so that the head of the screw prevents the pin from walking out.
Same idea as your zippies or my filler, but a more compact or more removable version...
Name : robotennis Age : 61 Location : las vegas Joined : 2007-12-17Post Count : 5562 Merit : 143
Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Aug 03, 2010 1:58 am
my idea would be to drill and tap a hole on each side of the pin,and place across the pin a thin piece of polyethylene plastic. and secure with pan head machine bolts.tiny ones.
example: .-O-. u get the idea...
Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Aug 03, 2010 2:11 am
Not bad, especially with a metal strap between the bolts. But with the 1-screw method, you don't have to mess with the weaker part of the 'ears'...
Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Aug 03, 2010 2:18 am
I think you may have totally misunderstood what I was trying to say. If I could use the software, or even had the software that a lot of you guys have, I could paint a better picture. The idea that Robo or whoever it was just mentioned of mounting a strap to keep the pin captured would work as well, just requires drilling 2 holes instead of one.
Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Aug 03, 2010 2:34 am
Rick wrote:The idea that Robo or whoever it was just mentioned of mounting a strap to keep the pin captured would work as well
Rick.. i love you too Ricker!
my Spanish idea is better though
Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Aug 03, 2010 2:39 am
Okay, now tell me that I'm the only one who thinks that Robo is insane...
Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Aug 03, 2010 2:53 am
If you were posting from CA, I'd swear you were an old friend in disguise. He is/was the only person that ever, in my life, referred to me as Ricker. Friggin strange, sort of like you. I still believe your idea will work, in skilled hands of course.
97SC_CALI_RIV Amateur
Name : Gabriel Location : NORTHERN CALIFORNIA Joined : 2011-04-15Post Count : 28 Merit : 0
Subject: STEERING COLUMN MOVING Mon May 16, 2011 10:04 pm
the steering column on my 97 riviera, i noticed, moves a little to the left. is this a common issue with these cars? its not a whole lot but if anyone that knows can help me fix it....that would be great.
Ok guys. I know we've had this discussion before, but we had no conclusion.... Many of us have this steering column problem, which relates directly to the pivot bushings that mate the upper column to the lower. MOST of us can fix this by simply by buying the bushing kit from the dealer and replacing them.
In my case (and many, many more of you), you may have tried to replace the bushings only to have the new ones fall right through the hole.....the upper housing holes are blown out. The upper column is no longer available, and if you're lucky enough to find one new (2 years ago there were only 2-3 left in the country), be prepared to pay $500. No other car shares our steering column. HOWEVER, with a parts breakdown diagram of a Riv column and Aurora column ('97-'99), turns out that the upper housing is the exact same piece! Almost no other parts are interchangeable (there are a couple) with each other, but that upper block is exactly the same.
So, if you've scoured junkyards only to find 9 million Auroras and no Rivs, and gone home empty handed, start rippin those damn Oldsmobiles apart! As soon as I get the time to do so, I'm there......I was at the pick 'n' pull 2 days ago. Not one Riv......but 7 Auroras.
Good Luck and happy hunting!
(if/when I go, I'll post the exact tools you will need to disassemble the column)
Name : Matthew Age : 36 Location : Florida Joined : 2007-01-17Post Count : 4394 Merit : 101
cant we just get a sleeve from mcmastercarr to take up the slack in the pin? I havent pulled mine apart yet to fix it but from the pics on page 10 i dont see where this wouldnt work. hard part would be finding the proper sizes sleeve since it depends on how bad yours is reamed out.
_________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily
Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sat Jun 04, 2011 2:06 am
I'm open to any way of fixing it. I was just confirming another column we can steal parts from. Eventually, I was going to take mine apart, fill the holes with aluminum and redrill them. But if I can find a good one at a yard, I'll spare myself the hassle
GreenMonster Amateur
Name : Todd Age : 40 Location : San Diego CA. Joined : 2011-06-23Post Count : 20 Merit : 3
Subject: temp Mon Jun 27, 2011 4:40 pm
I did not read all the pages but if it was not mentioned, how do you take the steering wheel off?? I'm trying to get the cruise control and wiper unit controls apart because both are acting up, I figure the contacts need to be cleaned but when I went to remove the steering column I noticed the two fasteners are not a standard shape or size. What do you use to get the steering column apart? Also, my steering wheel is also experiencing some play
Subject: temp Mon Jun 27, 2011 4:57 pm
If you in fact need to take the wheel off to access the cruise and wiper stalk, I'm not sure.
For steering column disassembly, there are a few parts diagrams and photos in this thread, starting on this page:
You do not need to remove the streering wheel to remove the multifunction switch, tho it may make it a bit easier. The front facing bolt can be removed with a looong extention if you turn the wheel right, and would be a bit easier with a swivel extention. When I tried to go behind the wheel I couldn't get the right angle because the socket wrench head kept hitting the wheel.
BMD Aficionado
Name : BMD Location : Canada Joined : 2009-04-28Post Count : 1161 Merit : 36
Name : Bartine Joined : 2011-08-15Post Count : 14 Merit : 0
Subject: Steering Column Fri Aug 19, 2011 1:49 pm
OK, Now that my AC is fixed I'll be heading to the junkyard to get a replacement steering column that is tighter than what is in the car. What GM cars have the same steering column, or is it jus the 1995-1999 Riv?
scroll up and read......
Name : Dave Age : 62 Location : In The AZ Oven Joined : 2007-01-17Post Count : 4502 Merit : 44
Finally got around to taking the Riv in to have them fix mine, they had quoted a couple hundred bucks for this. They found one missing pin and 1 broken pin, bracket not broken. No repair parts available anymore. They would find a used column and do a replacement. About $700. I said no thanks.
