 Surging Tach and Car when overdrive engages
GMFreak8
9 posters
Go to page : Previous  1, 2
GMFreak8
GMFreak8
Merit : 15
Surging Tach and Car when overdrive engages - Page 2 Empty
PostSubject: Re: Surging Tach and Car when overdrive engages   Surging Tach and Car when overdrive engages - Page 2 EmptyWed Jan 20, 2010 5:39 pm
Update: I've came to accept this surging as just a typical characteristic of the car
I have noticed a new thing though. It seems to hang onto a gear when coming to a stop. You can literally feel it sometimes lurch when you come to a more abrupt stop and it downshifts into first. This happened on my last car, but I can't remember what caused it. What exactly controls the downshifts and would cause it to hold a gear for too long on downshifts?
PostSubject: Re: Surging Tach and Car when overdrive engages   Surging Tach and Car when overdrive engages - Page 2 EmptyWed Jan 20, 2010 6:03 pm
I had a similar problem once when one of my vac lines cracked. There really wasn't any other symptom for me, otherwise the car ran fine. I also had a MAF sensor problem at the time. Both fixed, and issue went away.
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Surging Tach and Car when overdrive engages   Surging Tach and Car when overdrive engages - Page 2 EmptyWed Jan 20, 2010 6:17 pm
Yeah my last Buick had a similar issue and it had to do with a vacuum line. I can't remember what the vacuum line controlled though. I bet a line cracked slightly from the really cold weather we've been having here.
PostSubject: Re: Surging Tach and Car when overdrive engages   Surging Tach and Car when overdrive engages - Page 2 EmptyWed Jan 20, 2010 6:29 pm
I remember the Buick dealership took it out for a test drive and could not find the issue. Put up with it for some time, then took the car to INTENSE for an unrelated service; they found the cracked line, replaced it for free.
GMFreak8
GMFreak8
Merit : 15
PostSubject: Re: Surging Tach and Car when overdrive engages   Surging Tach and Car when overdrive engages - Page 2 EmptyWed Jan 20, 2010 6:53 pm
I'll have to look things over. I'm just driving it right now until things warm up and my checkbook recovers from christmas. Noticing the delayed shifts, the tick, and the clunk from the steering so far. I think the clunk is the steering knuckle or something. If you look down right directly where the steering linkage is under the brake reservoir you could see it noticeably move and wiggle along with having a feeling of clunkiness in the wheel whenever you turn it from off center. It seems to bind slightly midway when turning to the right too.
» 95 Riv Overdrive
» 98 riviera wont move in overdrive
» Welcome,and need help. No overdrive or cruise
» 2-stage overdrive???
» Lost Overdrive
