| Nitto Drag Radials 1996 riv | |
mrod7510 Member
| Subject: Re: Nitto Drag Radials 1996 riv Sat Jan 02, 2010 10:52 pm | |
| sick! now get some track times with them _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Nitto Drag Radials 1996 riv Sat Jan 02, 2010 11:31 pm | |
| awesome! What size did you get, how much did they cost? | |
| Subject: Re: Nitto Drag Radials 1996 riv Sat Jan 02, 2010 11:42 pm | |
| how do they do in the corners,and whats the life expectancy under normal driving? | |
mrod7510 Member
| Subject: Re: Nitto Drag Radials 1996 riv Sun Jan 03, 2010 1:11 am | |
| Well as far as track times yes im ready, test and tune is at the end of the month! your question of cornering, it feels the same as before, no rubs and i can turn the wheel all the way as in a u-turn fine. Price $300.05 discount tire, my friend works there. Life expectancy, who cares | |
T Riley Guru
| Subject: Re: Nitto Drag Radials 1996 riv Sun Jan 03, 2010 1:13 pm | |
| I have them...
Life expectancy? haha 5-10k miles if you DD the beast... mine lasted a summer and i have 1/6th tread left for this spring.. | |
mrod7510 Member
| Subject: Re: Nitto Drag Radials 1996 riv Sun Jan 03, 2010 3:16 pm | |
| Nice, I'll need a motor by then:) | |
T Riley Guru
| Subject: Re: Nitto Drag Radials 1996 riv Sun Jan 03, 2010 3:24 pm | |
| - mrod7510 wrote:
- Nice, I'll need a motor by then:)
Been through one of those in october... I really like the Nitto's even on the street they like to hook and book... I will be mounting them to some different rims and only using them for special occurrences from now on though... | |
| Subject: Re: Nitto Drag Radials 1996 riv Sun Jan 03, 2010 4:18 pm | |
| - Rickw wrote:
- deekster_caddy wrote:
- awesome! What size did you get, how much did they cost?
- mrod7510 wrote:
- Not many choices with my stock 16' rims so i went
with a Nitto NT555R 245/50/16 200% better, still spins a little with the nitrous in first gear, but drop the pressure to 20lbs and it hooks relatively well I think the OP was edited to add that info after I asked. It wasn't there when I posted the question, I swear! Thanks for pointing it out though! | |
| Subject: Re: Nitto Drag Radials 1996 riv | |
