| Alternator Failure, Voltage Spike! | |
+6Derek Abaddon deekster_caddy KillaKeninaRiv Rickw AA 10 posters |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8542 Merit : 181
 | Subject: Re: Alternator Failure, Voltage Spike! Thu Sep 22, 2011 8:40 pm | |
| - rivparadise wrote:
- Last week I was getting a low idle sometimes and it would pop a code saying low voltage to sensors etc. I replaced the alternator, however, I forgot to disconnect the battery and the lead wire fell on to the engine giving off quite a spark! I disconnected the battery and finished hooking everything up. Here's what I got! The transmission feels like I have the brakes on trying to go forward, almost like it's blown. The Air Bag light blinks a few times and then stays on. I took it to a shop where they told me there were NO fusable links blown and they suggested getting a new computer. I did and had it flashed to the car. No change and its still running terrible. Barely Idles and tranny still feels blown. Checked every fuse everywhere and none blown. HELP PLEASE!javascript:emoticonp('
') How long have you had your riv, and how long ago did this problem start/ This is one of the sort of issues where I'd hope to review maintenance history before troubleshooting. What i am wondering is if you're stuck in limp-home mode. The poor idle tells me maybe not. The poor performance and 'tranny feels blown' tells me maybe so. What I don't know is, why?
I would consider swapping in a known good ignition module and coils. are you getting a code now and what is it? Albertj | |
rivparadise Fanatic
Name : Samuel Age : 51 Location : Niagara Co. Joined : 2007-06-10 Post Count : 381 Merit : 11
 | Subject: Re: Alternator Failure, Voltage Spike! Thu Sep 22, 2011 11:00 pm | |
| Had this Riv for almost Three years now and no problems up until two months ago when the idle would go low only once in a while. Replaced IAC, MAF and TPS on the throttle body as well as cleaning it. Transmission shop guy told me I was in Limp Mode. | |
rivparadise Fanatic
 | Subject: Re: Alternator Failure, Voltage Spike! Thu Sep 22, 2011 11:11 pm | |
- No codes coming up yet!
Are you burning regular or premium gas? Do you use fuel from one station or several diff ones? Do you occasionally burn E-85 or do you think you mighta accidentally got a load of it? Did you consider pulling the oxygen sensors to look for white ash on them? Did you check the wiring to the O2 sensors? Albertj | |
rivparadise Fanatic
 | Subject: Re: Alternator Failure, Voltage Spike! Thu Sep 22, 2011 11:22 pm | |
| Always Premium, Several different stations, No E-85, Didn't pull O2 sensors but will in the morning along with wiring to them. | |
 | Subject: Re: Alternator Failure, Voltage Spike! Thu Sep 22, 2011 11:35 pm | |
| Don't just look at the oxy sensors, look at the others as well, the wiring especially. If you have the check engine light on get a scanner please and pull the codes, may tell you a little.
 | Subject: Re: Alternator Failure, Voltage Spike! Fri Sep 23, 2011 11:45 am | |
| Have you replaced spark plugs and wires? | |
rivparadise Fanatic
 | Subject: Re: Alternator Failure, Voltage Spike! Mon Sep 26, 2011 6:52 pm | |
| No codes from my buddys little scanner and I checked as much wiring as I could finding nothing. Took it to a speed shop here in town known for excellent work. They did a little today and found some codes but will get into the thick of it tomorrow. I will post what they find! Thank you all for your help. | |
rivparadise Fanatic
 | Subject: Re: Alternator Failure, Voltage Spike! Tue Sep 27, 2011 8:22 pm | |
| Guy at Speed shop said tranny was fine and alternator was putting out too much voltage. Car goes in to protect mode over 16 or so volts. Going to replace alternator tomorrow morning. | |
rivparadise Fanatic
 | Subject: Re: Alternator Failure, Voltage Spike! Fri Sep 30, 2011 7:20 am | |
| I just had the same problem! Our car have a safety feature that protects certain circuits from too much power. The car goes into LIMP mode! New alternator should do the trick. I got a new one from Carquest and it was throwing out 17.4. My car wouldn't run right either! Ordered another one and walla! Fixed! | |
 | Subject: Re: Alternator Failure, Voltage Spike!  | |
