 ''Doc dual plane mod history and results.....
4 posters
DocModisett
''Doc dual plane mod history and results..... Empty
PostSubject: ''Doc dual plane mod history and results.....   ''Doc dual plane mod history and results..... EmptySun May 02, 2010 10:25 am
A couple of years ago, i got an idea for an experimental mod for nailhead engines.... Since there are no single 4 high performance intake manifolds for the 1953 thru 1966 engines , I was turning this problem over in my mind and decided to do an experiment,,,, I removed the intake off my 64 rivs 425 engine and using a tungston carbide burr and a cut off wheel and a saws all,,, I port matched the intake ports to the head manifold gaskets and then I cut the dividers from between the FRONT and REAR barrels and LEFT THE CENTER DIVIDER IN.....Then I took my porting kit and the carbide burr and smoothed the cuts up real good ....The idea was to get better breathing on the intake, if the engine wanted it,,,, the whole thing cost me about $4 for sawsall blades....
I made no other changes what so ever.... nothing,,,, and put it back on the engine....same carb [afb] and same air cleaner....
There was a very good increase in power from start ,all the way thru the power band....i was amazed.... and also thought ,,, ''Why didn't Buick do that'...'
Since then several guys from another Buick site have done the same mod and it has caught on and even been given the monicker ''the Doc dual plane",,,,by them...
Just thought I would share,,,,
PostSubject: Re: ''Doc dual plane mod history and results.....   ''Doc dual plane mod history and results..... EmptySun May 02, 2010 2:50 pm
Sweet!
Tank
Tank
PostSubject: Re: ''Doc dual plane mod history and results.....   ''Doc dual plane mod history and results..... EmptySun May 02, 2010 4:41 pm
Thats awesome! Got any pics??
DocModisett
PostSubject: Re: ''Doc dual plane mod history and results.....   ''Doc dual plane mod history and results..... EmptySun May 02, 2010 5:00 pm
Right at this stage, I dont know if I have pics or not,,,, the brainbox on my computer crashed and I had to buy another one..... my pics were on the old one....i might be able to scare one up.....from somewhere.... dont know....just read the post real close, you will sort it out....
DocModisett
PostSubject: Re: ''Doc dual plane mod history and results.....   ''Doc dual plane mod history and results..... EmptyTue Sep 21, 2010 7:35 am
Well, one of my buddies did the ''Doc dual plane'' mod and his car picked up 2/10ths and 4 mph...
PostSubject: Re: ''Doc dual plane mod history and results.....   ''Doc dual plane mod history and results..... EmptyFri Sep 24, 2010 4:49 am
SO,it will give more, horses than torque?
DocModisett
PostSubject: Re: ''Doc dual plane mod history and results.....   ''Doc dual plane mod history and results..... EmptyFri Sep 24, 2010 7:52 pm
James,,,
Dunno about that,, all I know is that the cars we have done it to runs much better.... I just wonder why Buick did not do that back in the 50's when the horsepower races were on....
» has anyone done this mod? results??
» Unibody repair / cradle bushing replacement results
» dual inlet cai
» FAQ: The Exhaust Thread
» 1997 dual heated seats?
Riv Performance ::   N/A V8 Tech :: 425 V8 Engine & Transmission-
