 Write-Up: Custom Rear Adjustment Links
sniperdude
Derek
23 posters
Write-Up: Custom Rear Adjustment Links - Page 2 Empty
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyWed Apr 03, 2013 10:50 am
robo how hard is this and will it work on a 97?
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyWed Apr 03, 2013 10:58 am
well..you need to be able to weld and figure things out.other wise a really simple mod.
Merit : 17
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyWed Apr 03, 2013 12:03 pm
Robo, have you thought of making custom tie rods similar to this? Just curious, I don't think there would be any need, but who knows!
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyWed Apr 03, 2013 9:57 pm
Yeah,those are in the works too.I dont see much improvement over stock with a custom tie rod set? Aside from better bump steer control.But I dont see that I have or feel bump steer? But they will look so much cooler and the spherical bearing would be ten times better in quality than even the most high doller AC Delco brand and for less than half the price! for that reason alone it would be a great mod.
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyThu Apr 04, 2013 12:42 am
then im golden! if i ever have the time off to do them frown
have you made a write up on them robo?
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyThu Apr 04, 2013 12:45 am
uh,no.But I might do one when I get my spherical bushings in the control arms.I'll have it all disassembled so that would be a good time I guess.
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyThu Apr 04, 2013 1:22 am
sweet cant wait and ty bud
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyThu Apr 04, 2013 11:24 am
I should point out,I didnt make it clear in my post, that the RBM and the RSSA are two seperate parts.The RBM is sandwiched between the body and the RSSA.
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 2:52 pm
I went ahead and made the first version of a plug&play hardware kit go go along with the same exact stuff robo got. I can't weld for ass and I'd rather not make those kind of modifications to the RSSA anyway. I took measurements off the original arm (the sleeve area that connects to the RSSA) to get an overall size and went from there. So here is version 1...
Write-Up: Custom Rear Adjustment Links - Page 2 20130412_1323371
*The two M12x1.75 (same size as original studs) bolts were purchased (stainless)
*Then we have front washers that are 1.5" to take up all the space in the rear well to center everything (stainless)
*two pairs of specifically sized heim joint insulators if you will to fill the rest of the space in the RSSA bracket area and strategically limit the movement of the joint some (aluminum)
*the 5/8" OD, M12 bolt ID sleeves (aluminum)
*rear washer/nut combo also sized to 1.5" (stainless)
Write-Up: Custom Rear Adjustment Links - Page 2 20130412_1328171
close shot of the sleeve in the heim with a bolt
Write-Up: Custom Rear Adjustment Links - Page 2 20130412_1330151
the assembly
I'll share all sizes and probably make some cad/inventor files once I install and at least know it works and make any revisions.
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 2:57 pm
Oh man doze iz sweeet! I'ze a little jelly!
..oh,and get ready for some super handling you never thought the Riv capable of.
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 3:00 pm
right now I'm primarily just looking to make it go straight lol
Merit : 123
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 3:01 pm
VERY nice turt!
Would you sell a kit? I'd buy one to save myself duplicating it..
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 3:02 pm
dont worry,you'll be going straighter! without those old rusted links self indexing you all over the place if you know what I mean?
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 3:14 pm
Nice man,can u chrome them so they will never rust.....
Merit : 63
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 3:17 pm
Awesome job, Turtle. I'm very interested in the specs and pieces needed when you get everything squared away...
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 3:23 pm
Codith, is there anything different about your set-up vs. robo's?
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 3:42 pm
they're alu.no rust.the sphericals are plated.no rust.
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 3:51 pm
Ohhh....I see.Thanx....
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 4:25 pm
the sphericals might even be stainless? with chrome-moly bearings...no rust.
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptyFri Apr 12, 2013 5:37 pm
Ohh yeah that's nice u need it stainless. I hate rust,mine aren't pretty to look at,all rust........
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptySat Apr 13, 2013 1:24 am
Fundamentally not really. I'm mostly just using custom hardware to fasten it to the rear cradle instead of going through a tricky process of trying to drill the original elongated holes to a much bigger centered hole, and welding nuts to the RSSA. If all goes as planned, this should be a literally bolt-in deal.
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptySat Apr 13, 2013 9:22 am
I'll second Karma's post. If you want to piece together a "plug & play" kit i'd be interested too.
Write-Up: Custom Rear Adjustment Links - Page 2 Dsc_0110
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptySat Apr 13, 2013 9:54 am
Is the rear suspension identical on the 95-99 Rivieras such that this also would "bolt on" to a 95 or 96?
Depending on cost, I'd be interested as well.
Do you think this will be as durable as the OEM part?
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptySat Apr 13, 2013 12:12 pm
That's what I wanted to know. Thanks!
PostSubject: Re: Write-Up: Custom Rear Adjustment Links   Write-Up: Custom Rear Adjustment Links - Page 2 EmptySat Apr 13, 2013 5:23 pm
This is gonna be great!  I should add,dont think I made it clear,that the reason to modify the RBM is to hard mount it to the body.This way the adjustment link mod is completely hard mounted and all deflection is eliminated.This will give you TRUE handling with no slop.The rear control arms are soft rubber mounted but because they are mounted longitudinally they suffer somewhat due to the soft rubber bushings.The links control them perfectly.If they were mounted sideways like most rear control arms they would almost have to be modified to extract all performance benefits from a adjustable link.A spherical mounted control arm is Still a Must for a performance rear end.Thats next.
» Custom Rear Lateral Adjustment Arms/Links???
» Rear adjustment links and tie rods for Riviera
» Write-Up: rear shock air compressor (ELC)
» Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation
» Write-Up: Custom Y-Split Exhaust Pipes
