 Fender,Door Interchange.
3 posters
knuckled1
knuckled1
Fender,Door Interchange. Empty
PostSubject: Fender,Door Interchange.   Fender,Door Interchange. EmptySat Dec 18, 2010 12:59 am
I have a 98 with a small dent in fender and door. I picked up real nice doors and fenders from a 97. Will they line up properly? Will the window need to be adjusted to function correctly? I have keys for 97 doors but no key/alarm/trunk thingy. fab,phab whatever it is. Will my 98 work and what needs to be changed to achieve this? Any help would be greatly appreciated. Also can you buy new weatherstripping and window adjustment/alignment componets?
PostSubject: Re: Fender,Door Interchange.   Fender,Door Interchange. EmptySat Dec 18, 2010 1:54 am
you will have to get the key fob reprogramned. autozone has a service i think. go dealer,go big $.
as far as i know,all body panels are interchangable for series 1 and series 2.
its probably a good idea,if you dont have one allready,to get a service manual.
Merit : 90
PostSubject: Re: Fender,Door Interchange.   Fender,Door Interchange. EmptySat Dec 18, 2010 6:52 am
ALL body panels are the same from '95-'99, there might have been some slight cosmetic differences but all will bolt/weld up to all years. No way to know about the window adjustment until you got the door installed, it may or may not need to be adjusted.
knuckled1 wrote:
I have keys for 97 doors but no key/alarm/trunk thingy. fab,phab whatever it is. Will my 98 work and what needs to be changed to achieve this? Any help would be greatly appreciated.?
No changes would be needed, the remote is programmed for the car itself, not the door. You can install the lock cylinder from your old door into the replacement, that way the key would stay the same.
Don't know if they are available but the part numbers for the weatherstrip are:
W/Strip Door Opening
R ... 25640327
L ... 25640307
I believe all of the adjustments are made by moving the brackets in slots on the door mounting points, should not need any new components to accomplish an adjustment if required.
knuckled1
knuckled1
PostSubject: Re: Fender,Door Interchange.   Fender,Door Interchange. EmptySat Dec 18, 2010 3:57 pm
Awesome. Thank you to both 99rivman and robotennis61. I just have one other question. Any good sources for a used service manual set/ Or do they need to be purchased new/ Thanks again you guys are always a great help.
PostSubject: Re: Fender,Door Interchange.   Fender,Door Interchange. EmptySat Dec 18, 2010 4:14 pm
ebay has em sometimes,or go online and find the cheapest source. i paid about $87 buck brand new for my 2 vloume set. ive seen them go ,used, for as little a $30.....
Merit : 90
PostSubject: Re: Fender,Door Interchange.   Fender,Door Interchange. EmptySun Dec 19, 2010 7:56 pm
I have a '97 set for sale but not a '98, sorry bonk
