 FAQ: Cylinder Location & Firing Older
Natesriv
8 posters
Natesriv
Natesriv
FAQ: Cylinder Location & Firing Older Empty
PostSubject: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptySun Mar 14, 2010 6:01 pm
I'm about 2 seconds away from beating the car with a hammer!
Can somone PLEASE TELL ME what the cylinder numbers are? I mean, the coil packs have the cylinder number on them, but which one is #1, which is #2, etc...
Looking at the engine, standing in front of it....which cylinder is #1, which is number 2, etc...????
My shop manual doesn't have it, my owners manual doesn't
I'm this close to smashing the whole m'fking thing! smile
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptySun Mar 14, 2010 6:14 pm
http://ww2.justanswer.com/uploads/goodwrench9124/2009-02-24_011504_3.8_firing_order.THUMB.gif
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptySun Mar 14, 2010 6:15 pm
Calm down Nate.
There is a cylinder wiring diagram on here somewhere but I'll try to explain.
The Front three cylinders from left to right are #1 - #3 - #5
So the leaves the rear bank of cylinders from left to right while standing in front of the car to be:
#2 - #4 - #6
The FSM should have a diagram in there somewhere, I know I've seen it before. But this car has a very easy cylinder placement
and firing order to remember. (1,6,5,4,3,2)
Natesriv
Natesriv
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptySun Mar 14, 2010 6:30 pm
Turtle & Rick....
you two go get a beer! You saved my day!!!!
car is not smashed!
smile smile smile
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptySun Mar 14, 2010 6:34 pm
What are you doing to that poor car now.?
It didn't do anything to you, did it.?
Natesriv
Natesriv
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptySun Mar 14, 2010 9:07 pm
I took the s/c snout off again to reseal it. Was leaking very slowly..
In doing so I forgot the sequence to the cylinders and the coil packs...thought I had it, and car ran like crap for the 5 seconds I had it on... i had marked them, but it rubbed off
Looked in the shop manual...nothing... online...nothing..
then posted here and you guys saved me!
thank amigos!
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptySun Mar 14, 2010 9:30 pm
Did you use the Anaerobic Gasket Maker or something else.?
Also, next time you need to remove the ignition wires - before actually pulling them from the coil and plugs use some masking tape and mark each wire on each end with the cylinder number they came off of. It will help you avoid something as EMBARRASSING as this. j/k
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptyMon Mar 15, 2010 2:10 pm
I know this has been solved, but I'm bored at work and I thought a pic might help.....
FAQ: Cylinder Location & Firing Older Firingorder
Natesriv
Natesriv
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptyTue Mar 16, 2010 12:14 pm
I bought a kit on ebay and it came with a red gasket material I used... but I had sanded the snout when i took it off...and may have sanded too much...
So I bought some high temp red gasket material at the autoparts store and re-gooped the sh_t out of it. Then put it all back together.
is there some special gasket material we have to use? I don't think the turbine oil will eat this stuff...plus I lock-tight'ed the bolts this time. It appeared oil was leaking around the bolt threads....
LOCK TITE is damned expensive too! The stuff I bought was $21 for a little bottle!
Natesriv
Natesriv
Bought lock tite as i noticed one bolt loose on taking snout off again
bullseye-shawn
bullseye-shawn
PostSubject: Plug Wire & Cylinder Firing Older   FAQ: Cylinder Location & Firing Older EmptyFri Feb 25, 2011 12:03 pm
Hi guys ive been building my 2000 gtp all winter.
So far i got a certified transmission built trans 3200 stall
3.4" pulley
Nic cam
zzp pcm
3" all the way back to dual magnaflows (loud and rumbly)
Black out headlights
interceptor guage
SSAC headers
My problem is to get in the headers i undid all the plug wires and i would just like a diagram or a picture to make sure they are all right
Thanks shawn
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptyFri Feb 25, 2011 12:15 pm
FAQ: Cylinder Location & Firing Older Firingorder-1
bullseye-shawn
bullseye-shawn
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptyFri Feb 25, 2011 12:21 pm
Thanks a ton.
Had 2 swapped around
3 and 5 thanks abaddon
By the way Abaddon we have another car show at bullseye with a dyno rented if anyones interested. I know you were thinking of coming to the last one. ill have the rivi and gtp in it
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptyFri Feb 25, 2011 1:31 pm
Np man.
Lemme know when. I'm still working on the new engine. Things have slowed to a crawl at work though, so the $$$ intake for the Rivi engine has ceased......
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptyFri Feb 25, 2011 1:39 pm
Np man.
The Bodyshop Lull -- the dumb deer have all been whacked for the most part and the tourist-driven surprise-stop-and-left-turn-from-right-lane season has not yet begun - that season comes at/after Easter weekend.
TIme to paint/service/upgrade the equipment and degrease the floor and stuff while we live off road-kill venison in the fridge...
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptyFri Feb 25, 2011 1:52 pm
Right......actually, the body shop is busy as hell. It's the mechanical end (me) that's slow as hell. People around here just don't have the $$$ to fix their cars, or their spending their $$$ elsewhere. Had a guy come in with 2005ish Ram. SES light was on, he didn't care. He had a Remote Start installed instead......wtf scratch
adri
PostSubject: firing order   FAQ: Cylinder Location & Firing Older EmptyWed Feb 01, 2012 5:10 pm
hey guys! hi i was wondering if anyone knows THE CORRECT FIRING ORDER for my 1995 Riv? its NOT Supercharged. PWEEEEASE!!! bounce
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptyWed Feb 01, 2012 5:13 pm
1-6-5-4-3-2
adri
PostSubject: Re: FAQ: Cylinder Location & Firing Older   FAQ: Cylinder Location & Firing Older EmptyWed Feb 01, 2012 5:23 pm
Thanks Aaron!
» One of my Rivs
» Hope you dig older stuff............
» cylinder heads
» Write-Up: Brake Master Cylinder - Install & Bench Bleed
» misfire cylinder 4
