 Nail Head help
4 posters
stevenm
Nail Head help Empty
PostSubject: Nail Head help   Nail Head help EmptySun Jul 17, 2011 8:05 pm
any one got nail head knowhow
Merit : 150
PostSubject: Re: Nail Head help   Nail Head help EmptyMon Jul 18, 2011 11:55 am
www.v8buick.com
http://www.v8buick.com/forumdisplay.php?f=9
clearway
PostSubject: temp   Nail Head help EmptySat Aug 20, 2011 12:41 pm
Hello, Dale here, I do have the '95 service manual, books 1 & 2, I've owned a '63 & 64, long gone but a lot of fun. Currently I own a '95 of course.
DocModisett
PostSubject: nail heads......   Nail Head help EmptySat Oct 29, 2011 10:34 am
I have been known to build a nailhead or 2..... happy What is your question????
DocModisett
PostSubject: Re: Nail Head help   Nail Head help EmptySat Oct 29, 2011 11:08 am
Steven,,,,
In my opinion, the nailhead buick engines that were built from 1953 thru 1966 were the best engines that buick has ever built except for maby and I say maybe the GN engines that came later.....
The 1953 engine should be avoided because buick improved the later ones so much more making them easier to work with.... All of them had forged steel cranks, forged steel rods, hi nickle engine blocks and heads,,,, good free flowing exhaust manifolds,,, they are tough as a boot .... they have good cooling systems, and good oiling system that needs no mods to support a performance engine... there is a bunch of vintage speed equipment,,,,, intakes,,, 2x4's,, 3x2's,,, everything except a single 4 aluminum intake, which I am working on now,,,,, lol but you can do my Doc dual plane mod on a factory single 4 and come up with a real good performing manifold....
You can get finned aluminum rocker arm covers and a finned aluminum lifter valley cover,,,plus the 1966 th400 switch pitch trans will fit engines from 1959 on up..... but be carefull swapping transmissions and do your home work because buick used a closed drive shaft untill 1960 or so.... to swap in the th400 you need a open drive line....
just some ideas......
Nail Head help
» Bose Amp and Subwoofer
» Aftermarket Head Unit Install?
» no low head lights need help
» headgasket?????
» head bolts
Riv Performance ::   N/A V8 Tech :: 425 V8 Engine & Transmission-
