 Tire size
3 posters
Tire size Empty
PostSubject: Tire size   Tire size EmptySat Oct 01, 2011 3:40 pm
What tire size would be better, for easier turnig. 225 55 16 or 205 50 16? Thanks and why!!!
Merit : 149
Tire size Empty
PostSubject: Re: Tire size   Tire size EmptySat Oct 01, 2011 4:09 pm
Not sure what you mean, easier turning? The 225/55-16 will be 25.74" tall, and the 205/50-16 will be 24" tall. The stock tire for the 95-99 Rivs is 225/60-16, and that is 26.6" tall. The shorter tire will give you a higher numerical gear ratio, and that means the engine will rev higher at any given speed. What are you trying to accomplish?
Tire size Empty
PostSubject: Re: Tire size   Tire size EmptySat Oct 01, 2011 5:39 pm
A narrower tire will turn easier.there is less rubber digging into the ground.not taking into account power steering.
then there are other questions,HP of the car. it gets complicated.
Tire size Empty
PostSubject: Re: Tire size   Tire size EmptySat Oct 01, 2011 9:55 pm
Thanks, that's what i thought!!!
Tire size Empty
Tire size
» Ideal Tire Size
» Tire Size Question
» Tire Size/Offset - What are you running?
» Write-Up: Spindle / Wheel Bearing / Hub Replacement
» 3.2" pulley belt size?
