Rod.G Rookie
Name : Sherrod Age : 50 Location : Bolingbrook,Il. Joined : 2012-04-12 Post Count : 16 Merit : 0
 | Subject: Lost power. S/C grind Thu Apr 19, 2012 7:44 pm | |
| I don't have the rattling sound but I do now have a slight grind/rubbing type of noise and the boost is pretty weak. I'm pretty sure I'm not getting the 7-9 psi out of my s/c. I will soon purchase a boost gauge to find out exactly what I'm getting. I never before put s/c oil in, I have 168k, I just changed plugs and wires, boost solenoid is opening up while reving up and I have a small manifold intake leak. Quite a bummer without full power...any suggestions anyone?
 | Subject: Re: Lost power. S/C grind Thu Apr 19, 2012 9:18 pm | |
| have you tried removing the belt and spinning the pulley by hand to see if something is catching? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
Rod.G Rookie
 | Subject: Re: Lost power. S/C grind Thu Apr 19, 2012 9:42 pm | |
| No I haven't. I'll definitely start there | |
Rod.G Rookie
 | Subject: Re: Lost power. S/C grind Thu Apr 19, 2012 9:50 pm | |
| Btw. I do get the chirping on the start-up but it eventually quiets down. So you think it may be the tentioner pulley? Or the pulley on the snout of the s/c? Educate me please Also, while its running I can put my hand on the cover of the s/c and feel what may be the grind/rubbing sound Was kinda hoping I could add s/c oil and it stops | |
 | Subject: Re: Lost power. S/C grind Fri Apr 20, 2012 7:42 am | |
| Please add at least the year of your car to your signature, and activate it. Year and SC or NA is minimum important information for anyone helping with your issue. | |
Rod.G Rookie
 | Subject: Re: Lost power. S/C grind Fri Apr 20, 2012 10:43 am | |
| Sorry. Thanks Derek. I have a 95 s/c with 168k mileage. I'll add to signature | |
Rod.G Rookie
 | Subject: quick diagnose Thu Apr 26, 2012 2:31 pm | |
| I did remove belt and I did find that there was about 1/4 of play twisting pulley back and forth. Guess its the coupler. Thanks for the tips guys. | |
 | Subject: Re: Lost power. S/C grind  | |
