| Yeah...I bought this... | |
Natesriv Addict
Name : Nate Age : 52 Location : KCMO Joined : 2007-01-18 Post Count : 509 Merit : 16
 | Subject: Yeah...I bought this... Fri Aug 10, 2012 9:31 am | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8517 Merit : 181
 | Subject: Re: Yeah...I bought this... Fri Aug 10, 2012 10:26 pm | |
| If corrosion is not a problem for you, consider mounting the horns fore of the radiator. you may want to make a 'custom' bracket to hold them, try to point them downward and forward somehow - point toward the ground that you can see when you look down behind front bumper. .
Alternatively consider mounting behind the radiator support, but be aware of the fans and the movement of the engine in the mounts.
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Sun Aug 12, 2012 2:04 pm | |
| Yeah, they're combined together it appears... might take some customization...
should be in next week...I'll post pics! | |
IBx1 Expert
Name : ILAN Age : 31 Location : College Station, TX Joined : 2007-12-30 Post Count : 4304 Merit : 69
 | Subject: Re: Yeah...I bought this... Mon Aug 13, 2012 11:30 pm | |
| If you can find room for those in the EP3 let me know! I've always been thinking of installing train horns just for fun, but my idea was to have a small onboard compressor tank in the trunk that I would refill with an air pump that wasn't installed on the car, kind of like filling tanks of NO2.
Edit: let me know how these are supposed to get wired up, I want!!! | |
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Tue Aug 14, 2012 4:18 pm | |
| I hope they come in soon!
They appear to have a wire & relay. But unless my horn relay is too weak or whatnot in the Riviera then I should only need to hook up the horn compressors .
I had put air horns on my old Sunbird Turbo GT (loved that car's looks but TOTAL junk!!!) But the metal diaphram which made the noise just tore... and the horn was useless...
These look to perhaps have a better construction...
Since the Riv has two horns...two power wires...
But I'll read the instructions fully before I just snip & clip.
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Tue Aug 14, 2012 4:19 pm | |
| Now on an EP3 Si...there's NO room I'm sure! Well, maybe in the hatchback! Thinking of selling my EP3 too. | |
IBx1 Expert
 | Subject: Re: Yeah...I bought this... Wed Aug 15, 2012 9:08 am | |
| I think there might be space behind the lower grille and where the stock horns go, although I didn't get the dimensions of these. Keep us posted! | |
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Fri Aug 17, 2012 7:16 pm | |
| NOPE...
Damn! Okay, since there are two compressors that takes up space.
I tried to put them on the frame in front of the oil pan. The ONLY place they'd fit. But there's just no room to install them with the hardware they come with. The setup comes with two nuts and bolts...but you can't tighten a bolt in the subframe since it's a closed tube.... so I went and bought some self tapping screws... that'd work.
However, to install the two compressors and tighten them down AND allow room for the horns....just not enough room in my setup design, and not enough daylight.
Space was tight so I thought I'd grind down the trumpets for more room...that's high quality metal...my dremel took awhile... But alas, it still didn't align up enough to NOT show underneath the car (and scape every driveway & speedbump)
So I put it back in the box for another day.... | |
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Fri Aug 17, 2012 7:18 pm | |
| So , this sized airhorns are too large...but damn they're loud (you can blow into the tube and make them work....HONK!!!)
Option 1: Smaller air horns...more Ferrari sounding...but not GM
Option 2: Older 80's Cadillac horns...they were awesome
Option 3. Get new OEM horn...boom ...done
denim Junkie
Name : Sean Location : Albany, NY Joined : 2011-08-27 Post Count : 923 Merit : 33
 | Subject: Re: Yeah...I bought this... Fri Aug 17, 2012 10:07 pm | |
| Your next post? "Yeah, I sold this..."  | |
IBx1 Expert
 | Subject: Re: Yeah...I bought this... Fri Aug 17, 2012 11:16 pm | |
| Sorry for the Honda talk, but I was thinking of putting these horns through the hole where the intake usually runs on my fender well in the engine bay, since my car has a CAI and not a FWI. Were they really that hard to fit on the Riv? What are the rough dimensions of the compressors? | |
charlieRobinson Expert
Name : Charlie Age : 37 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3922 Merit : 30
 | Subject: Re: Yeah...I bought this... Sat Aug 18, 2012 12:52 am | |
| yo, Ilan. I checked out all your old riv pics and threads yesterday. I am surprised you still hang out here without owning a riv. Why did you decide to get rid of it anyways? | |
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3104 Merit : 104
 | Subject: Re: Yeah...I bought this... Sat Aug 18, 2012 4:29 am | |
| - Natesriv wrote:
- So , this sized airhorns are too large...but damn they're loud (you can blow into the tube and make them work....HONK!!!)
Good choice! There is little mounting space under the hood of the Riv, but I added the "Low-D" horn from my '81 Eldorado to the existing 2 Buick horns to make this car sound like a proper 'Merican car... | |
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Sat Aug 18, 2012 5:56 pm | |
| the compressors are 2/3 of a coke can (height).... if you get under the car the ONLY space is the subframe between the oil pan and that tubular subframe crossmember....
The compressors need to be upright, so you have to figure a way to do that in a closed tube...you can't tighten the bolt, since the nut is inside the tube...impossible....
BUT, I was thinking of some metal straping, or something similiar to hold them in place...
On a Honda...no room. The biggest horn is 14" or so long...too long...
And actually...reallly...the quality of construction leaves enough to be desired that I'd mount it in such a way as to be able to remove it when they go kaput!
It seems nobody makes a quality air horn... | |
Natesriv Addict
| so, yeah.... Cadillac horns...deeper, richer...old school.
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Sat Aug 18, 2012 6:08 pm | |
| for a Honda Civic Si...I think of Hella horns... two options ...I had one...it was LOUD 1 (the one I had) From here 2 (sweet) A twin air horn kit...WOW Like from here | |
IBx1 Expert
 | Subject: Re: Yeah...I bought this... Sat Aug 18, 2012 11:12 pm | |
| I wouldn't go with the whiny squeaky horns; I may buy an ooga horn though.
Also, Charlie, RP was my home page since I joined and the community here is strong enough that I never changed that, even when I switched computers. I'll be staying on ClubEP3 after I get a Focus ST in a few years as well. | |
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Sun Aug 19, 2012 10:27 am | |
| damn Focus ST's are expensive, but awesome...and no 3-doors  The top horn(s) aren't too whiny...they are like REALLY loud versions of what we have in the EP3 right now. The second are like horns in an old Alfa Romeo I'd say | |
denim Junkie
 | Subject: Re: Yeah...I bought this... Mon Aug 20, 2012 9:55 am | |
IBx1 Expert
 | Subject: Re: Yeah...I bought this... Fri Aug 31, 2012 12:35 am | |
 | Subject: Re: Yeah...I bought this... Fri Aug 31, 2012 12:58 am | |
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Fri Aug 31, 2012 8:56 am | |
| I love it! Well I sold the Si back to Carmax...so I'm a one car owner now (not counting the wife's Accord)
I'm not ENTIRELY sure how much longer I'll keep the Riv, but until then...it's the smoothest car I've ever owned.
The Si was fun, but just felt the time was right for something newer...with a little more luxury...
IBx1 Expert
 | Subject: Re: Yeah...I bought this... Fri Aug 31, 2012 8:58 am | |
| Glad you had fun with the EP, maybe look for one of the new Regals with a 6-speed if you want fun, new, and luxury? | |
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Fri Aug 31, 2012 9:00 am | |
| good point...aren't they turbo's? | |
Natesriv Addict
 | Subject: Re: Yeah...I bought this... Fri Aug 31, 2012 9:07 am | |
| funny thing...thinking hard about keeping the Riv, or getting an 80's vette instead...and then getting an LTZ Sonic 1.4 Turbo...  peppy (not Si RPM'y) but leather... and closer to 40mpg (with lighter foot) | |
 | Subject: Re: Yeah...I bought this...  | |
